New Mesh Head !
New Mesh Head !
2010-08-24 by bigbearstyx
Guys just rec'vd a Pintech (by Roland) dual zone 10 in snare, used.
But, in what looks to be good shape. 1st mesh head so it's new to me.
Do I need to really re-adjust sensitivity for this snare now.?
I hit the mesh head and unless im exactly over the piezo I don't resister a good hit..AND its kinda spotty--
 missing some hits (if I really hit it hard and in the center).
Wondering if its a setting, multiple settings or Maybe the mesh head is bad? ?
thxs
BBs
Re: [DTXpress] New Mesh Head !
2010-08-24 by David Scarponi
Does the drum have a foam rubber cylinder between the mesh head and the piezo?
That was the old style design for Pintech, not sure about newer ones.  I
replaced the cylinder with a tapered design from Roland which seems to work
better.  You can also replace the mesh head with a regular head and see what
happens.  And eventually you may need to play around with module sensitivity.
My impression is Pintech mesh drums aren't the best, but you can get them to
work okay with a little effort.
To: DTXpress@yahoogroups.com
Sent: Tue, August 24, 2010 1:58:53 AM
Subject: [DTXpress] New Mesh Head !
thxs
BBs
Re: New Mesh Head !
2010-08-26 by keith1200rs
You might want to try adjusting the attenuator switch at the back of the module.  I run with all reject settings at zero and MVEL=1 and GAIN=99 but then I use a snare stand, not the rack.  On the rack you may need some rejection settings other than zero.
I have also added a small 100k potentiometer that I soldered to the connector in the shell to help tame the signal.
With the cylindrical foam the pads can tend to be over-sensitive in the centre.  I think if you buy or make a cone (something that Roland patented and wouldn't let Pintech use even though they allow Pintech to use other aspects of the Roland patents) it may improve.  I think the cones are more progressive from the centre.  The other thing that makes a difference, I am told, is a two ply mesh head.  The Pintech is single ply whereas the Roland heads are double ply.
Keith.
Re: [DTXpress] Re: New Mesh Head !
2010-08-26 by David Scarponi
Can you still buy the Roland foam cones for a retrofit?  M. Friend used to have
them, but last time I checked, they were no longer available.
Sent: Thu, August 26, 2010 3:49:25 AM
Subject: [DTXpress] Re: New Mesh Head !
other than zero.
Keith.
Re: New Mesh Head !
I don't know, but this is the place to ask:
http://www.vdrums.com/forum/forumdisplay.php?f=48
If not, there is plenty of information there about making your own, I think.
Keith.
RE: {Cleaned} [DTXpress] Re: New Mesh Head !
2010-08-26 by Damon, Rob
You will have to order them directly from Roland. I think they will only sell a maximum of 6 at a time and I don\u2019t recall how much they were, but I don\u2019t remember them being cheap. You can occasionally find someone on the web that sales \u201cbootleg\u201d versions of them. Or like Keith said, do a google search on how to make your own.
Rob \u2013OGD
From: DTXpress@yahoogroups.com [mailto:DTXpress@yahoogroups.com] On Behalf Of keith1200rs
Sent: Thursday, August 26, 2010 10:23 AM
Subject: {Cleaned} [DTXpress] Re: New Mesh Head !
> them, but last time I checked, they were no longer available.Â
Keith.
This message has been scanned for viruses and
dangerous content by the Richweb.com MailScanner and is
believed to be clean.
