Hi Chris,
I'm going to give you two answers, as there is a cable
that goes to the HH pedal, and one that goes to the HH
pad.
The HH pedal needs a stereo (you may see it called a
TRS) 1/4" male phone to 1/4" male phone cable. These
come in various lengths, and one place you can get
them is Drumbalaya.com. Here's an
example:http://shopping.netledger.com/app/site/site.nl?site=ACCT97787&mode=items&sc=2&category=41&it=A&id=692
Now, you can use that same cable for your HH pad, but
chances are that you only have a single trigger pad
for your HH, and if so you can get a mono 1/4" male
phone to 1/4" male phone ExamplesExamlpes of mono pads
would be TP60, TP80, PCY60 or PCY80. Yamaha usually
adds the letter S to the end of models that have
stereo triggers, like TP80S as an example. Here's a
mono cable
http://shopping.netledger.com/app/site/site.nl?site=ACCT97787&mode=items&sc=2&category=40&it=A&id=690
The mono cables are simply guitar cords, but the
stereo ones are a little harder to find. You can
visually tell the difference by looking at the plugs -
the stereo has three sections (called the Tip, Ring
and sleeve or TRS for short) while the mono only has
two sections. Both type come in various lengths -
choose what you need.
Hope this helps,
Walt
-- cs_williams <chris_williams@...> wrote:
> Bought a used DTXpress and the hi-hat patch cord is
> flaky. Opened it
> up and the solder job was very close to
> disconnected. I tried re-
> soldering with no luck.
> So...any suggestions on exactly what type of patch
> cord I should buy
> and where I can get it online? My local shop
> doesn't have a very
> good selection.
> Thanks,
> Chris
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
