DTXchange on DTXPRESS II
2003-03-13 by skygrim2002
thx this group to exist, so, I would like to know if DTXCHANGE software works on the DTXpress II, and on WINDOWS XP...i think it works but i want to be sure. ANd is the all tips in this group are available on DTXpress II ? THX A french man, DAMs
2003-03-13 by Walt
Hi Dams, Welcome to the group, and we hope you have as much fun with your DTXpress II as we have with our kits! There were some posts in this group over the last month that confirmed that DTXchange does work with Windows BP and the DTXpress II, so you should be able to use them together. There is a way to search the posts to find the ones on that topic. If I understand your second question correctly, you were asking if the tips about the DTXpress will work on the DTXpress II, and my answer is that most of them do apply to the DTXpress II. There are, of course, some differences between the two versions, but most of the operations and concepts are the same on the two versions. Certainly if you have specific questions just let us know. There are 2 things we have found about the DTXPress II that I will warn you about. First, I would suggest that one of the very first things you do is to reset your module to the Factory Default settings. I recommend this because several people have had trouble connecting MIDI devices to the DTXpress II, and after reseting the module, the problems are resolved. Even if you do not have plans to use MIDI now, it is easier to reset the module before you customize it, because the reset erases your unique settings. The second problem is that the default settings for rejections between the snare and HH are wrong, which causes a problem when both pads are hit together. The symptom is that if you hit the snare and HH together, one of them may not make a sound, because the rejection settings are incorrect. I hope this helps you to get started... Walt --- skygrim2002 <sky@...> wrote: > thx this group to exist, > > so, I would like to know if DTXCHANGE software works > on the DTXpress > II, and on WINDOWS XP...i think it works but i want > to be sure. > > ANd is the all tips in this group are available on > DTXpress II ? > > THX > > A french man, > DAMs > > __________________________________________________ Do you Yahoo!? Yahoo! Web Hosting - establish your business online http://webhosting.yahoo.com
hi, I really thank you for your help, and your speed to reply my post. i have no probleme with the "rejections between the snare and HH" at this time... i'll test midi connection, and perhaps reset if not work... i m sorry for my english... Thx, thx thx and rethx. Dams a french DTXPress'guy. --- In DTXpress@yahoogroups.com, Walt <wgardus@y...> wrote:
> Hi Dams, > > Welcome to the group, and we hope you have as much fun > with your DTXpress II as we have with our kits! > > There were some posts in this group over the last > month that confirmed that DTXchange does work with > Windows BP and the DTXpress II, so you should be able > to use them together. There is a way to search the > posts to find the ones on that topic. > > If I understand your second question correctly, you > were asking if the tips about the DTXpress will work > on the DTXpress II, and my answer is that most of them > do apply to the DTXpress II. There are, of course, > some differences between the two versions, but most of > the operations and concepts are the same on the two > versions. > > Certainly if you have specific questions just let us > know. There are 2 things we have found about the > DTXPress II that I will warn you about. First, I > would suggest that one of the very first things you do > is to reset your module to the Factory Default > settings. I recommend this because several people > have had trouble connecting MIDI devices to the > DTXpress II, and after reseting the module, the > problems are resolved. Even if you do not have plans > to use MIDI now, it is easier to reset the module > before you customize it, because the reset erases your > unique settings. > > The second problem is that the default settings for > rejections between the snare and HH are wrong, which > causes a problem when both pads are hit together. The > symptom is that if you hit the snare and HH together, > one of them may not make a sound, because the > rejection settings are incorrect. > > I hope this helps you to get started... > > Walt > > --- skygrim2002 <sky@f...> wrote: > > thx this group to exist, > > > > so, I would like to know if DTXCHANGE software works > > on the DTXpress > > II, and on WINDOWS XP...i think it works but i want > > to be sure. > > > > ANd is the all tips in this group are available on > > DTXpress II ? > > > > THX > > > > A french man, > > DAMs > > > > > > > __________________________________________________ > Do you Yahoo!? > Yahoo! Web Hosting - establish your business online > http://webhosting.yahoo.com
2003-03-13 by Walt
Hi Dams, You do not need to apologize for your English - I know you communicate much better in English, than I can communicate in French! Walt --- skygrim2002 <sky@...> wrote: > hi, > I really thank you for your help, and your speed to > reply my post. > > i have no probleme with the "rejections between the > snare and HH" at > this time... > > i'll test midi connection, and perhaps reset if not > work... > > i m sorry for my english... > > Thx, thx thx and rethx. > > Dams > a french DTXPress'guy. > > --- In DTXpress@yahoogroups.com, Walt <wgardus@y...> > wrote: > > Hi Dams, > > > > Welcome to the group, and we hope you have as much > fun > > with your DTXpress II as we have with our kits! > > > > There were some posts in this group over the last > > month that confirmed that DTXchange does work with > > Windows BP and the DTXpress II, so you should be > able > > to use them together. There is a way to search > the > > posts to find the ones on that topic. > > > > If I understand your second question correctly, > you > > were asking if the tips about the DTXpress will > work > > on the DTXpress II, and my answer is that most of > them > > do apply to the DTXpress II. There are, of > course, > > some differences between the two versions, but > most of > > the operations and concepts are the same on the > two > > versions. > > > > Certainly if you have specific questions just let > us > > know. There are 2 things we have found about the > > DTXPress II that I will warn you about. First, I > > would suggest that one of the very first things > you do > > is to reset your module to the Factory Default > > settings. I recommend this because several people > > have had trouble connecting MIDI devices to the > > DTXpress II, and after reseting the module, the > > problems are resolved. Even if you do not have > plans > > to use MIDI now, it is easier to reset the module > > before you customize it, because the reset erases > your > > unique settings. > > > > The second problem is that the default settings > for > > rejections between the snare and HH are wrong, > which > > causes a problem when both pads are hit together. > The > > symptom is that if you hit the snare and HH > together, > > one of them may not make a sound, because the > > rejection settings are incorrect. > > > > I hope this helps you to get started... > > > > Walt > > > > --- skygrim2002 <sky@f...> wrote: > > > thx this group to exist, > > > > > > so, I would like to know if DTXCHANGE software > works > > > on the DTXpress > > > II, and on WINDOWS XP...i think it works but i > want > > > to be sure. > > > > > > ANd is the all tips in this group are available > on > > > DTXpress II ? > > > > > > THX > > > > > > A french man, > > > DAMs > > > > > > > > > > > > __________________________________________________ > > Do you Yahoo!? > > Yahoo! Web Hosting - establish your business > online > > http://webhosting.yahoo.com > > __________________________________________________ Do you Yahoo!? Yahoo! Web Hosting - establish your business online http://webhosting.yahoo.com
2003-03-13 by wfaraoni
I could not get the bulk dump to work with windows xp and with the dtxpress II, however the kits were transfrerable. let me know if you figure out a fix Bill --- In DTXpress@yahoogroups.com, Walt <wgardus@y...> wrote:
> Hi Dams, > > You do not need to apologize for your English - I know > you communicate much better in English, than I can > communicate in French! Walt > --- skygrim2002 <sky@f...> wrote: > > hi, > > I really thank you for your help, and your speed to > > reply my post. > > > > i have no probleme with the "rejections between the > > snare and HH" at > > this time... > > > > i'll test midi connection, and perhaps reset if not > > work... > > > > i m sorry for my english... > > > > Thx, thx thx and rethx. > > > > Dams > > a french DTXPress'guy. > > > > --- In DTXpress@yahoogroups.com, Walt <wgardus@y...> > > wrote: > > > Hi Dams, > > > > > > Welcome to the group, and we hope you have as much > > fun > > > with your DTXpress II as we have with our kits! > > > > > > There were some posts in this group over the last > > > month that confirmed that DTXchange does work with > > > Windows BP and the DTXpress II, so you should be > > able > > > to use them together. There is a way to search > > the > > > posts to find the ones on that topic. > > > > > > If I understand your second question correctly, > > you > > > were asking if the tips about the DTXpress will > > work > > > on the DTXpress II, and my answer is that most of > > them > > > do apply to the DTXpress II. There are, of > > course, > > > some differences between the two versions, but > > most of > > > the operations and concepts are the same on the > > two > > > versions. > > > > > > Certainly if you have specific questions just let > > us > > > know. There are 2 things we have found about the > > > DTXPress II that I will warn you about. First, I > > > would suggest that one of the very first things > > you do > > > is to reset your module to the Factory Default > > > settings. I recommend this because several people > > > have had trouble connecting MIDI devices to the > > > DTXpress II, and after reseting the module, the > > > problems are resolved. Even if you do not have > > plans > > > to use MIDI now, it is easier to reset the module > > > before you customize it, because the reset erases > > your > > > unique settings. > > > > > > The second problem is that the default settings > > for > > > rejections between the snare and HH are wrong, > > which > > > causes a problem when both pads are hit together. > > The > > > symptom is that if you hit the snare and HH > > together, > > > one of them may not make a sound, because the > > > rejection settings are incorrect. > > > > > > I hope this helps you to get started... > > > > > > Walt > > > > > > --- skygrim2002 <sky@f...> wrote: > > > > thx this group to exist, > > > > > > > > so, I would like to know if DTXCHANGE software > > works > > > > on the DTXpress > > > > II, and on WINDOWS XP...i think it works but i > > want > > > > to be sure. > > > > > > > > ANd is the all tips in this group are available > > on > > > > DTXpress II ? > > > > > > > > THX > > > > > > > > A french man, > > > > DAMs > > > > > > > > > > > > > > > > > __________________________________________________ > > > Do you Yahoo!? > > > Yahoo! Web Hosting - establish your business > > online > > > http://webhosting.yahoo.com > > > > > > > __________________________________________________ > Do you Yahoo!? > Yahoo! Web Hosting - establish your business online > http://webhosting.yahoo.com
