Hey, thanks Scott. I found 5-4 in my manual (I've got the first model
DTXpress, too). I followed the instructions, but it made no
difference. Let me check this with you... I call up the Kit that I
want to tie to a particular song (Kit No. 72), then find KIT Common
in the Voice menu, select the Song number (96) and the tempo (183)
thus: SongSel= 96d=183. Then I press the SAVE/ENTER button, and store
it to that Drumkit. Did I miss anything out? Then, when I switch to
Song No. 96 from the one immediately before or after it, I should see
the kit automatically change to No. 72, shouldn't I? It doesn't work
for me - it automatically defaults to Kit No. 40 GM std 1.
--- In DTXpress@yahoogroups.com, "hairytrigger" <artifax@i...> wrote:
> PS this info is on page 47 of the DTXpress manual.5-4 Song Select.
Top
> of second column. DTXpressII I don't know.
> Scott
wrote:
> > OK Go into the voice menu. Page up until yopu get to the 'KIT
> common'
> > menus. the menu will say SongSelect= ---d=---. Here select the
song
> > number you want to call up with the kit you are in. AND set the
> > tempo(d=---) (the 'd' is the note symbol) SAVE it here!. Don't go
> back
> > to the play mode to save it. I just tried it. It works.
> > Scott
> > --- In DTXpress@yahoogroups.com, "liberatusvirus"
> > <liberatusvirus@y...> wrote:
> > > Nick,
> > > Our problem solving seems to have left a lot to be desired in
your
> > > case. The kit/song predicament has been gnawing at my brain
> (what's
> > > left of it); I had a feeling that it had come up before. Lo and
> > > behold, if you search the archives for "Assigning a kit to a
> song,"
> > > you'll find that on March 12 of last year, someone asked the
same
> > > question and received what would have seemed to be a
> straightforward
> > > answer from the always reliable Walt--pressing "save" should
> > > associate a song with a selected kit once and for all--but this
> time
> > > to no avail. No one else had any ideas about it. There have
been
> > > complaints about fluid settings from the very beginning. Maybe
> > > people just learned to live with them, though I agree with you
> that
> > > this tendency in the module is annoying and perplexing. Maybe
> we'll
> > > come up with a solution yet, even if we have to get Yamaha
> involved
> > > again.
> > > It's amazing how many things come up on the board that stump
you,
> > > regardless of how long you've been a member. I think that you
can
> > > disable a pad's choke by setting the pad type in the trigger
menu
> to
> > > one that doesn't support it. I've never done it, but I seem to
> > > recall someone saying so.
> > > As for the bow/rim interaction on, I assume, the Yamaha stereo
> > > cymbals. I'm not sure that this would technically be an issue
of
> > > crosstalk (though it would be on a dual-zone cymbal). This is a
> > > common, legitimate complaint about this type of cymbal. I think
of
> a
> > > stereo cymbal's reliablity as measured on two fronts: (1) its
> > > tendency to make a sound other than the one intended and (2)
its
> > > tendency to make any sound at all. Though some stereo cymbals
are
> > > better than others in both cases or in one of them, they all
> suffer
> > > from similar maladies, in my experience. One of the problems is
> > > that, given the geography of bow and rim, it's often hard to
> strike
> > > one without implicating the other. The one you strike first is
> > > one you'll get, and the harder you hit, the more likely you are
to
> > > strike the wrong one first. Tilt has something to do with it as
> > > well. With some of them, hitting the rim in a certain
> spot--usually
> > > off to the side--will result in the bow sound. I've tried the
> > > Yamahas, a Roland or two, and the Pintech Zenbals. At the
higher
> > > reaches of the Roland spectrum (where the prices get shamefully
> > > high), the problem is minimal. Simply put, I think that Yamaha
has
> > > to make a round cymbal, with more real estate and more
attention
> to
> > > detail. To my mind, price being a consideration, the Pintech
> Zenbal
> > > stereo cymbal marks a huge step forward in performance. Other
> people
> > > may have had a different reaction to it, but mine was that it
was
> > > vastly better in reliability on both fronts. In fact, it almost
> > > never gives no sound at all; once in a while, it will give the
> > > unintended one. (Stephen recently upgraded to all Zenbals; he
> should
> > > be able to add valuable information.)
> > > I think I went over my 2 cent limit, but interesting questions
> all.
> > > Ed
> > > --- In DTXpress@yahoogroups.com, Nick Carroll
<njcarroll56@y...>
> > > wrote:
> > > > Thank you, Vernon Graner. I saw your reply to a new DTXpress
> > > owner, and - as a relatively new owner myself - I checked out
your
> > > very good DTXpressions.com web site. Those tips & tricks are
very
> > > useful. I am particularly interested in TIps & Tricks #6,
about
> > > crossfading the bell with cymbal, so that hitting the top part
of
> > > the ride cymbal pad (the more responsive part) will get more of
a
> > > bell sound. I'll try that out and let you know how I get on.
> > > > There is one problem I haven't resolved yet, despite some
> pointers
> > > by the list Editor and Underneathheaven (thanks for your
efforts,
> > > guys!).
> > > > And that is, how do you assign a particular kit to a song, so
> that
> > > when you change to that song, the kit changes also? The
> factory-set
> > > songs #1 thru #95 all do this, so I figure there must be a
way.
> Ed
> > > suggested I check the UT Midi Program Change Table Kit
assignments
> > > in the Utilities menu. So I went in and changed things around,
> but
> > > it made no difference. When I changed from one song I had
> > > programmed to another, the brain still defaulted to Kit #40 GM
std
> > > 1. Am I missing out a step?
> > > > Here are two others posers: Is there any way to stop the
choke
> > > function on the ride cymbal rim? And sometimes when I hit the
> ride
> > > cymbal, I get the ride-rim sound instead - is there a way to
> reduce
> > > the crosstalk between them?
> > > > Yahoo! Mobile
> > > > - Check & compose your email via SMS on your Telstra or
Vodafone
> > > mobile.
