AX14s
2003-08-14 by hairytrigger
Ed, In your reply re: dual-zone stuff, you stated that a splitter was required for the AX14s to the 9/10. Since the 14s ia a dual-zone with a trs jack, and the 9/10 is a trs jack, all you need is a stereo cable.... IF you use the 9/10 for head and rim. The splitter is required if you want to use the input 2 and 9 or 10 for rim. I use the input#2 for head, because all the kits are set up that way, not that many are useble anyway. Just a little more info to confuse the issue... Scott
