Possible Hart's problem?
2003-09-12 by jtatsuoka
I just saw a pict of the  Hart Prosnare innards along with a schematic and understand why it probably won't work on a DTXpress.  Under
the mesh head is a approx. 6 inch foam cylinder  (1 inch diameter) positioned in the center that transfers  energy to a 10 inch diameter
aluminum plate.  The piezo is  underneath this plate.  This probably eliminates the hot spot that Roland mesh pads are know for but
would be WAY too small of a signal for the DTxpress.
Roland piezo's are 2 inches from the head with a cone shaped foam material transfering energy directly to the piezo.
According to this schematic the Prosnare has 3 piezos.  One under the aluminum plate and TWO on the shell of the drum.   One of the
shell  piezo's and the center piezo is wired in parallel. This is a very curious third piezo.  It would seem every time you hit the rim the center
sound triggers too?!
Jun
Re: Possible Hart's problem?
2003-09-12 by liberatusvirus
Under
diameter
but
Jun,
Seems plausible.
the center
I'm just guessing, but maybe the parallel piezos create a kind of rim
to pad effect, or, more likely, are used for positional sensing with
certain voices, via the Roland TD-10's expansion card.
Ed
2003-09-13 by jtatsuoka
Ed,
The Roland dual zone mesh pads only have two piezos. According to td-8 and td-10 users on electronicdrums.com,  the only requirement
for positional sensing is the mesh head piezo to be centered.
Jun
2003-09-13 by liberatusvirus
Jun,
Well, I thought as much, but the three piezos threw me. I've been
checking out what the Hart lovers at vdrums.com have had to say.
Surprisingly, no one mentions the third trigger--only the advance of
the Pro over the Accupad so far as plug n' play is concerned and the
amelioration of the hot spot. If you get a clue about what the extra
piezo is doing on the shell from the schematic, please post it. Could
it simply be providing better coverage of the head? Apparently, the
Accupad stopped triggering effectively an inch away from the rim.
I'll stop speculating.
Ed
