Upgrading - hardware needed?
2003-09-11 by yoavf21
Hi Guys
I currently have the standard Dtxpress II kit and based upon your
recommendations I plan on buying a Pintech ConcertCast Pad.
Do I need any extra hardware to connect it to kit? I want to keep
using the current snare pad - so do I need anything else except the
pad itself?
Thanks
Yoav
Re: Upgrading - hardware needed?
2003-09-12 by liberatusvirus
--- In DTXpress@yahoogroups.com, "yoavf21" <yoavf21@y...> wrote:
> Hi Guys
> pad itself?
Yoav,
If you're getting the dual-zone version, you'll need a TRS splitter
to for the Pintech's male stereo output and two mono cables for,
presumably, input 2 (body) and 9 or 10 (rim); the other option is one
stereo cable for 9/10 (both rim and body). That should do it. You'll
have to tinker with the pad type and other trigger settings; we can
help if you need us. The other consideration is how you're going to
mount it. The Xpress rod and clamp--appropriately turned for the
Pintech's orientation, will, in principle, do the job, but it remains
to be seen whether you'll be satisfied; if I recall, you'd have to
pull the rack arm toward you a little more. It's not inconceivable
that you might try a separate stand, which would have the advantage
of opening up your trigger settings.
Ed
2003-09-12 by yoavf21
Thanks Ed.
I was asking just about the mounting: If I mount the pintech on the
dtxpress clamp I'll need another clamp for the snare pad I already
have, right?
Yoav
remains
advantage
> Ed
> Thanks Ed.
> have, right?
Yoav,
Right, you'll need another clamp and rod, but I don't remember how
much real estate you have left on the Yamaha rack to mount another
pad. Call or email Ed Morin at Drumbalaya. Tell him what you're
doing, and he'll sell you what you need.
Ed
Expansian capacity??
2003-09-12 by kevin
hi all,
i am considering to expand my dtxpress kit...
the module is old dtxpress... and i wanna know
how many more pads can be added into the original
kit? and how?
thanks a lot!
kevin
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
Re: Expansian capacity??
--- In DTXpress@yahoogroups.com, kevin <vai_lee@y...> wrote:
> hi all,
> kit? and how?
Kevin,
If you still have the stock kit connected to the module, input 9/10
will be free. This dual-mono input will either take a single dual-
zone pad--for example, cymbal w/bell, mesh head snare w/rim, or
certain tubular triggers--or two mono (for instance, TP65, TP60, and
TP80) or two stereo/three-voice pads (like the PCY65, 65S, TP65S, 65,
etc.), which will perform only like mono pads through this input. You
can expand the kit by connecting a MIDI device with inputs of its own
that takes its voices from a sound module--such as the current Roland
TMC-6 or the discontinued PM-16, Kat Midikiti, et al.--or get another
sound module for inputs and run both modules through a mixer. The
MIDI device option on the Xpress would be fine for many users' needs,
but the Xpress' MIDI note numbers available for this kind of
expansion is limited (OGD probably couldn't manage it with his three
linked kits). The option of a second module would cover all the
contingencies (given the funds and a preferred module)--except one.
Available room on the rack is scarce. You might have to start adding
arms to fit the mounts, unless you could forestall it by using
separate stands. Drumbalaya.com is good at adapting peoples' rack
needs with their added triggers. You could deal with them; some of
their inventory is used.
Ed
Re: [DTXpress] Re: Expansian capacity??
2003-09-14 by kevin
thanks a lot dude!
but i am still wondering can i connect
two mono pads to a stereo input? (that
means i use the rim input connected as an individual
pad?)
kevin
> > hi all,
> > kit? and how?
> Kevin,
> module, input 9/10
> a single dual-
> snare w/rim, or
> TP65, TP60, and
> inputs of its own
> the current Roland
> al.--or get another
> a mixer. The
> many users' needs,
> kind of
> it with his three
> cover all the
> to start adding
> it by using
> peoples' rack
> them; some of
> Ed
Do you Yahoo!?
2003-09-14 by liberatusvirus
> thanks a lot dude!
> pad?)
Kevin,
In short, no. We've gone into detail on this matter many times before
so I won't do it this time. Suffice it to say that stereo pads are
really just mono pads in sheeps' clothing. If not played through a
dedicated stereo input, they revert to one sound. The rim voice is
not a separate zone; the FSR is just a toggle for the piezo in the
body of the pad.
Ed
