Thanks for your reply, Ed. Yes I think I've got my adaptors around
the wrong way. I'll have another look at it...
--- In DTXpress@yahoogroups.com, "liberatusvirus"
<liberatusvirus@y...> wrote:
> --- In DTXpress@yahoogroups.com, "Nick Carroll" <njcarroll56@y...>
> wrote:
> > I have started using a splitter on my 9/10 input so I can get one
> > sound on my bar pad and a different sound on my bell pad. The
only
> > problem is that the splitter always connects the A pad on the bar
> and
> > not the B pad, which is the one I prefer to use. Has anyone had
> > same problem, and can you tell me what to do?
> Hi Nick,
> Does the barpad have two separate leads corresponding to its two
> sections, or does it have one? I'm assuming that it has one. It
> sounds like you may be using the wrong splitter, or no splitter,
out
> of the barpad. What you need is a TRS "Y" adaptor to distinguish
> the "A pad" from the "B pad." The single stereo lead (the bottom of
> the "Y") goes into the barpad, and the two mono leads at the other
> end correspond to the tip and ring of the single stereo connector.
If
> you're using a splitter for the barpad that has stereo connectors
on
> the two leads instead of tip/ring mono ones (or if you're using no
> TRS splitter at all), the badpad signal won't divide properly. You
> should use the same kind of TRS "Y" interconnect to access 9/10
from
> the separate mono feeds as well. Did I hit or miss your point?
> Ed
