Thanks Stewart.....! ABOUT #6 and DIP switches
2003-10-26 by JD Jerry Davis /Team Bozi Drummer
Thats exactly what I thought. (to do)
I just wanted to make sure. Im new to this electronic drumming.
I see the DIP switches,
Q: Do these switches actually help "Boost" my sound?
Can I flip up the #6 switch *and achive a stronger Ride sound now
with the stock Yamaha PCY65 Ride (Im currently useing) ???
Would it help? The sound now (stock/factory settings) is kind of
week.
Crash comes through the mix.....good & loud.
The Ride (i feel) is overall week.
and just my opinion: The hi-hats???? Well they are totaly WEEK!
* The pedal, does NOT feel/sound/ or work 1/2 as well as accoustic.
Then again, I use 15" Zildjians on my accoustic kit to get
FULL/MAXIMUM projection.
Re: Thanks Stewart.....! ABOUT #6 and DIP switches
2003-10-26 by moosetication
Yes. But then again, no.
On the subject of the effect of the switches, a problem is that
whoever labelled the switches and wrote the manual didn't really
understand the word "attenuate" and "high/low" in that regard.
Basically, flicking the DIP switch up (to "high") reduces the
attenuation and so increases the strength of the signal and
therefore volume.
However, before you do that, read on...
> Ride sound now with the stock Yamaha PCY65 Ride
I think you need to be careful here, as you're rushing into things.
The DIP switch for a pad is a very crude control of volume. It's a
bit like swatting flies with a Buick. The switch is really meant to
help you to match other pads (such as the Visulite ride) that have
weaker signals than the Yamaha pads, to be tracked by the module.
Before you go there, you need to spend a little time with the
manual, looking at settings that affect your sound. You should try
different ride voices, and remember that you can have two layered
voices on each pad which can either be stacked (both sound at the
same time) or velocity cross-faded (the voice changes the harder you
strike the pad). Some people use velocity cross-fade to achieve a
bow and bell sound - a lower velocity strike triggers a bow sound,
and a harder strike a bell sound.
You need to understand the various things that affect volume and
responsiveness, such as minimum velocity, gain, pad response curve,
voice volume, overall kit volume, and finally the volume control on
the front. You should be adjusting these WAY before you head for the
DIP switches on the back with standard Yamaha pads. There's no
substitute for coming to grips with the manual and how this thing
works, I'm afraid.
Hats are a weak point of most electronic kits, both at the pedal
(which doesn't give the same control of "opening" as an acoustic
pedal) and with their voices, which tend to need adjustment to be
even close to satisfactory. Again, layering and adjusting decay
(sustain) can make a big difference.
There is one e-drum hi-hat pedal which comes close - the Visulite,
beloved of Ed - and we have high hopes for the new Yamaha hi-hat on
the DTXpressIII.
Remember one thing above all: an e-drum kit is not a perfect
facsimile of an acoustic kit. It's an electronic instrument which
you play in much the same way as a drum set. That's an important
distinction. If you approach this any other way, you're in for
disappointment.
Stewart
2003-10-27 by liberatusvirus
--- In DTXpress@yahoogroups.com, "moosetication" <moosetication@y...>
JD,
Sorry I left you hanging, but I was out of town nowhere near a
computer. I want to add one thing to Stewart's helpful post. The Visu-
lite ride doesn't have a particularly weak signal (in fact, it's
pretty strong). To my mind, however, Stewart is right on the money
about the DIP switches. Before you mess with them, you have to get to
know firsthand what the module's internal settings can do and what
they can't do. Climbing the e-drum learning curve is absolutely
essential to feeing in control and getting the most out of the
equipment. The sensitivity parameters are not volume controls. The
DIP switches are mainly to boost the signal of triggered acoustic
drums to the point at which gain can be set to allow decent dynamic
range. But they can also help with mesh head pads, as well as any e-
drum components that could benefit from a little goosing. They will
not, however, compensate for any pad that is completely mismatched
with Yamaha electronics for anatomical reasons, such as the Hart ECII
ride.
What I should have said about saving the bow of the ride for input 6
is that such a strategy will always allow you the option to flip the
switch up if you prefer (I had all of mine up because my pads were
non-Yamaha cymbals and woven pads). But that is a secondary matter.
First square away the settings in the voice and trigger menus of all
pads, and see what you've got. When you've done this grunt work (and
checked in here), then you can start looking for extraneous ways to
improve response if need be, or for components that are more to your
liking. Case in point: Lots of experienced people on this board who
use the Pintech mesh snare find that the Xpress module tends to
compress its dynamic range. One method suggested for resolving the
problem is to insert a 200k pot in the cable between the head output
and the module input, attenuating the signal until only the hardest
hits register the most gain. Unless you know the characteristics of
the module and the pad in question, the solution is just a matter of
faith.
I can't stress enough the importance of learning firsthand the
strengths and limitations of the equipment that you own. The desire
to take shortcuts--even with "good" advice--can leave you vulnerable,
frustrated, and disillusioned. The more you understand, the more
confident we can be about our answers and the less you'll feel like
you're at someone else's mercy. You've barely had your DTXpress, and
here I am recommending the Visu-lite ride before you have any idea of
whether, or how, it could fit into your situation. I stand by my
recommendation, but in some respects, I'm getting ahead of you.
Ed
Ed
