any advice to my problem? DTX and Battery
2004-01-05 by rolf_antonsson
Hello, my name is Rolf and im a new owner of DTXpress II (1,5 month),
and I do like it! But I've come to an end of my struggling with
getting the midi thing working!!! I want to use DTXII with Native
Instruments Battery and I cant figure it out, how to get it
going!!! Everytime I start to play to play for, let say, 20 seconds,
then a big "crack" appears and the sound goes away!!
Please help me to configure the midi, and the module right!!
The stuff I use is:
DTXpressII
Win98SE
Cubasis 4.0
I have a fast processor and nearly 1 Gig RAM so the computor shouldnt
be the problem here.(and also newinstalled every program and drives)
I have looked in the DTXII manual plenty of time but I dont really
seem to get it...
Thanks for your help
Rolf Antonsson
Re: any advice to my problem? DTX and Battery
2004-01-05 by emf
month),
seconds,
> The stuff I use is:
> DTXpressII
> Win98SE
> Cubasis 4.0
shouldnt
> seem to get it...
Rolf,
Do you get an error message on the module screen? I've never used
Battery, so I can't help with that, but if it's a problem with how
the DTXpress is set up, somebody should be able to find it. You
aren't by any chance creating a MIDI loop back through the DTXpress,
thereby overloading it and shutting it down? If so, De-activate MIDI
thru.
Ed
> month),
> seconds,
> > The stuff I use is:
> > DTXpressII
> > Win98SE
> > Cubasis 4.0
> shouldnt
drives)
really
> > seem to get it...
> Rolf,
DTXpress,
MIDI
> thru.
> Ed
Hi, thank you for your tips!
no, I dont get any error messages on the DTXpressII, and I was also
wondering about the "midi loop" you were speaking about.. but I have
like every parameter in the DTX switched off, so im dont really have
a
clue on whats going on!! Im doing the trial and error method here...!
If I de-activate the midi thru from the sequencer (which I dont think
you ment) I dont get any sound at all.
Well, im still stucked..
Rolf
2004-01-05 by emf
have
> a
here...!
think
Rolf,
I know that it's a pain in the neck, but can you briefly outline just
how Battery, Cubasis, and the DTXpress II module are connected? Then
someone can attack each point along the chain to try and figure out
what isn't functioning correctly. The fact that you get 20 seconds or
so of sound before it explodes into silence seems to indicate that a
device is getting jammed at some point. The DTXpress internal
generator is off; its MIDI merge is off; note numbers are set . . . .
Is the final audio coming out of your PC or the DTXpress
outputs/phones? What is the exact MIDI path to the audio endpoint?
Hopefully, your response will strike a chord with someone.
Ed
also wondering about the "midi loop" you were speaking about.. but I
> have like every parameter in the DTX switched off, so im dont really
have a clue on whats going on!! Im doing the trial and error method
> here...!If I de-activate the midi thru from the sequencer (which I
dont think you ment) I dont get any sound at all.
> Rolf,
just how Battery, Cubasis, and the DTXpress II module are connected?
Then someone can attack each point along the chain to try and figure
out what isn't functioning correctly. The fact that you get 20 seconds
or so of sound before it explodes into silence seems to indicate that
a device is getting jammed at some point. The DTXpress internal
> Ed
Hello
The final audio is from my pc, as I want to use the Battery samples.
about the midipath I rather hand out a dump than a report by word, as
I dont feel myself to familiar with all the data-termilogy.
http://www.grajnd.net/images/cubasis.jpg
and one more thing, that maybe is of importance, I use AMD Athlon
1700+ with VIA chipset KT266/333 which this site
http://www.georgebreese.com/net/software/#PCI
speaks negative about,
I dont really know if, its inside the computer the fault is, or
Battery (dont think so) or the DTXpress (dont think so either, im
just confused wich parameter to switch on/off. I would really like to
hear from someone thats doing it with a sampler)
I dont know if I explain anything for the better know, I hope so.
I will not remove the cubasis pic until this thing is solved.
my stats again:
processor AMD Athlon 1700+, Chipset VIA
ram 896 Mb
soundcard Delta Audiophile
sequencer Cubasis 4
DTXpressII (of cause)
Rolf
2004-01-06 by buggoutbill
Rolf,
Do you have access to a MIDI keyboard controller? If so, can you
connect it to your card and play the Battery VST using it, for more
than 20 seconds?
Just trying to rule out the DTXPress as the problem.
Do you have the latest drivers for your soundcard installed?
I do not have Battery, but I do have Cubase and Reason. I will
attempt to use my DTXpress to control both tonight.
The patch for VIA chipsets is interesting. I knew the
older "Southbridge" chips, 686B, had issues, but I didn't know the
newer ones did too. My next mobo will probably not be a VIA at this
point (I have issues with my USB MIDISport sometimes).
Bill
as
to
> my stats again:
> ram 896 Mb
> sequencer Cubasis 4
> Rolf
OK, I just tried it out using Cubase VST 5.1, with the LM-9 plugin,
and it worked. The only thing I had to do was change MIDI note
numbers on the DTXpress. I played for over a few minutes without any
lockups.
Then I fired up Reason, and after a few tweaks to the DTXpress's MIDI
note numbers, was able to control Reason with it. No lockups their
either.
My rig:
Athlon 1.2, Gigabyte motherboard w/ VIA chipset
512MB Ram
Echo MIA soundcard
M-Audio USB Midisport 2x2
Windows XP Pro
Also, my box is streamlined for audio. No games, no Instant
Messengers, RealPlayers, Office, nothing. Except Cubase, Reason,
SoundForge, etc. The usual music-making stuff.
Make sure you don't have any 'extra' programs running: Instant
Messenger, Real Player, firewalls, anti-virus, file-swapping progams,
etc.
You may want to run a progam like Ad-Aware to cleanup any 'spyware'
that may be on your system, which may be causing problems.
Without actually being in front of your computer, I have to take some
wild guesses. Please bear with me. :)
> Hello
as
to
> my stats again:
> ram 896 Mb
> sequencer Cubasis 4
> Rolf
2004-01-06 by rolf_antonsson
Hey Bill, thanks for your tips
I have a midi keyboard, which I drummed on before, but its not the
same, isnt it? ;)
but I can connect it to check how Battery will respond.
I have the latest drives for the soundcard, and I do shot down all
programs, like Antivirus program, Zonealarm, hey I've even removed IE
with IEradicator! I dont use office or games, as I receantly
reinstalled everything to get this thing solved!
I just posted a message in the Battery forum, about the midi
controller in Battery, what to do with it..
All midinotes are correctly setup within DTX and so, anyway, I will
get the keyboard now.
-Rolf (thanks for staying with me :)
> lockups.
MIDI
> either.
> My rig:
> 512MB Ram
> Echo MIA soundcard
> Windows XP Pro
progams,
> etc.
some wild guesses. Please bear with me. :)
Rolf
2004-01-06 by drumsix12
--- In DTXpress@yahoogroups.com, "buggoutbill" <wnofi@e...> wrote:
> Rolf,
> than 20 seconds?
> Bill
samples.
word,
> as
like
> to
> > my stats again:
> > ram 896 Mb
> > sequencer Cubasis 4
> > Rolf
Rolf,
 it looks like a midi buffer overflow to me.
I'm using my dtxpress I with Nuendo 2.0 en Cubase SX (i don't think
the version is an issue here) and ik works fine for me.
I record the audio of my dtx along with a midi channel and no
problems there.
Maybe you're midi buffer is too small. I don't know exactly where to
do this but there is a setting in Cubase where you can increase your
midi buffer size.
Is it also hanging when you play a slow thing. So when you're not
generating much midi notes in 20 sec?
And another thing, when you're playing live (hearing sound) with
battery, that means you're direct monitoring is on in cubase. This is
a very heavy task for Cubase and you're PC. Maybe it's a latency
thins and that you're audio buffer goes crazy.
Good Luck,
drumsix
Holland
> Rolf,
> problems there.
> midi buffer size.
is
> Good Luck,
> drumsix
> Holland
Hello Drumsix
thank your for the information, it makes sence, I don't know how to
change the Midi buffer but I'll give it a shot. You are absolutely
right about the "slow thing". If I play slow, the sound cuts off right
away.
about the monitoring, can I do in some other way without hearing it?
(even if I just record the midinotes, the "glitch come" and destroyes
the recording)
can you play with a good latency that stills give you a "drum
feeling"? cuz I cant possible play with sounds hearing afterward I hit
the pads..
I will check out the buffer!
-Rolf
2004-01-07 by buggoutbill
Rolf,
It looks like you are loading Chainer (with Battery in it) and the
Battery VST. Try just using the Battery VST by itself in Cubasis,
without Chainer, and see if it makes a difference.
Also, in Cubasis--Options--Audio Setup, make sure you are using the
WDM driver, if possible.
Bill
as
to
> my stats again:
> ram 896 Mb
> sequencer Cubasis 4
> Rolf
