Tennis ball platform
2004-01-16 by Chris
I'm considering building one of the tennis ball isolation platforms
( http://www.dtxpressions.com/platform/ ) but space is an issue for
me.  In order to move freely around the room where my kit is I move
the throne away when not playing.  If I had a platform that was big
enough to accommodate both kit and throne I'd be falling over it all
the time! :-)
Therefore, I wondered if it is really necessary to have the stool
isolated from the floor.  It's certainly got enough height
adjustment to be able to rise up a tennis ball's worth.  Any
thoughts?
Also, has anyone actually built such a platform (stool on or off!)?
Chris
Re: Tennis ball platform
2004-01-16 by emf
all
> the time! :-)
> thoughts?
Chris,
Check out post 6505 for someone in the UK who built it and seems to
have had success.  Maybe you can contact him privately. Another
option is located at  http://www.clearsonic.com/--especially the
Isofloor section--though I don't know if it would be of any help to
you IN THE UK.
Ed
2004-01-17 by Rob
What does a tennis ball platform do? Is it for e drums or accoustics?
platforms
for
move
big
> all
> > the time! :-)
> > thoughts?
off!)?
> Chris,
> you IN THE UK.
> Ed
2004-01-17 by Chris
accoustics?
As far as I'm aware it's a platform that someone designed to reduce
the amount of vibration that passes from the kit to (and therefore
through) the floor, particularly from the pedals.
I'm not sure how useful it would be for an acoustic kit as it
wouldn't do much to reduce the sounds of the drums themselves but
for an electronic kit it seems ideal (if it works!).
Here's the link to the instructions in case you missed it in my
earlier post - http://www.dtxpressions.com/platform
Chris
2004-01-17 by Chris
to
to
> you IN THE UK.
Thanks Ed.  Not sure how I missed his post either originally or
during my search of the archives.  I shall try harder in future! :-)
I'll probably wait a few days to see if he posts here in this thread
and if not will try to contact him direct.  It seems more polite
that way and as we all now this is a very polite group,  certainly
the most polite I've ever been involved with.
Chris
2004-01-17 by Rob
Maybe another way to reduce vibration is to suspend a platform with
bungie cords, or heavy springs which are rubber mounted to both the
ceiling and the floor, and for complete ridance of vibration, is to
have such a platform in which thousands of opposing refrigerator
magnets are attached to each surface for suspension, obviosly you
would have to attach lanyards to keep the platform from hitting the
walls, and all thats left is ambient vibration, and thats a whole
different matter I will leave up to a sound guy......
Rob
> accoustics?
> Chris
Re: [DTXpress] Re: Tennis ball platform
2004-01-17 by Stephanie Ellison
> walls,
Unless you also install another thousands' group of those fridge magnets along
the walls and the suspended platform edges.  You may want to build a short
perimeter wall fitted with those magnets.  That wall would encircle the
platform, giving about 9 inches of space (or however it works out depending
on the magnets) in each direction.  However, don't forget to install several
magnets on the corners of the platform and walls so that the platform can't
rotate in place.  You not only want to keep the platform floating, you also
want it to stay in place horizontally and not spin on its vertical axis.
But two things...  I didn't know that there are these refridgerator magnets
around.  Won't they be too heavy for floors built out of wood?  What about
health effects of being inside these giant magnetic fields?
If you know you're going to be there for a long time, you can build an
isolation room inside the room your drums are in.  Just don't build it so
that there's construction on the structures of the apartment itself.  Try
building it so that it can be taken down and moved to another apartment,
leaving no evidence that such a room was ever there except for the
depressions in the carpet (furniture does that, too).  Also, make it so that
you can easily substract or add floor/wall space to fit the dimensions of the
new room whenever you move.
Here's what you can do.  I don't see myself owning a house in this lifetime,
but the next best thing is to rent room and board in a house owned by someone
responsible, someone who works for a living (so you can play while she's out
somewhere).  In other words, the home owner is my roommate.  I pay $350 +
utilities a month for my own use of part of the house, instead of the $450
(not good areas) to $700 (pretty nice areas) a month that's common in Austin.
That way, sharing common structures is not an issue AND I get to use my money
for other things, like getting more drum stuff and lessons ;-).
If you're in an apartment lease and you have a few months to go, talk to your
landlord about moving to a ground floor unit in the apartment complex.
Sometimes, they'll allow that, like they did with my previous roommate when
we moved in together into a larger apartment.
I hope this helps, because it's made a big difference in my life when I
decided to make changes that would benefit me as a musician, and I feel very
good about it.
Good luck!  Let us know how it goes!
Stephanie
Re: Tennis ball platform / Clearsonic Iso-Floor
2004-01-28 by sjr41
Hi Ed,
Thanks for the tip on the Clearsonic IsoFloor
(http://www.clearsonic.com/) -- I checked out the website, and it
looks like a really good (tho not exactly cheap) alternative to
building the tennis ball platform discussed below, which I am really
not so inclined to build...
I live in a small apartment in NYC, and have had problems with the
vibrations from my kick pedal rattling the dishes & the picture
frames on the walls of the apartment below me & bothering the
neighbors down there.
So, my question is -- has anybody out there actually tried the
IsoFloor, & if so, how effective is it in cutting vibrations?  Any
input on this product, pro or con, would be very much appreciated.
Also, given my space & monetary limitations, I am wondering whether
it might be effective to just get two of the 1' x 1' IsoFloor squares
(one for the kick pedal & one for the HH, so both feet are level),
instead of buying enough to make a full platform for the entire kit &
throne...  Any thoughts on this approach?
Finally, besides the tennis-ball thing, has anyone else come up with
good (& cheap) ways to minimize the vibrations of the kick pedal?
My neighbor is being very understanding, overall, but I'd love to
take care of this ASAP, so anything the group can do to advise me on
this would be great.
Thanks!
Scott
platforms
for
move
big
> all
> > the time! :-)
> > thoughts?
off!)?
> Chris,
> you IN THE UK.
> Ed
2004-01-28 by rdamon@mckinney-usa.com
Scott,
What you need to try is to just play on the pads only as a trial. Don't use
the hihat or bass pedal. Then see if that causes any problems for the
neighbors. If it does then you may have to go with the full platform. If
that doesn't bother them, then you maybe able to get away with something
limited to just isolating the pedals.
OGD
> From:	sjr41 [SMTP:sjr41@...]
> Sent:	Wednesday, January 28, 2004 3:57 PM
> To:	DTXpress@yahoogroups.com
> Subject:	[DTXpress] Re: Tennis ball platform / Clearsonic Iso-Floor
> Hi Ed,
> ( <http://www.clearsonic.com/)> -- I checked out the website, and it
> Thanks!
> Scott
> platforms
> > > ( <http://www.dtxpressions.com/platform/> ) but space is an issue
> for
> move
> big
> > all
> > > the time! :-)
> > > thoughts?
> off!)?
> > Chris,
> > option is located at   <http://www.clearsonic.com/--especially> the
> > you IN THE UK.
> > Ed
> Community email addresses:
>    Post message: DTXpress@yahoogroups.com
>    Subscribe:     DTXpress-subscribe@yahoogroups.com
>    Unsubscribe:   DTXpress-unsubscribe@yahoogroups.com
>    List owner:    DTXpress-owner@yahoogroups.com
> Shortcut URL to this page:
>    <http://groups.yahoo.com/group/DTXpress>
> Alternate DTXpress site:
>    <http://www.dtxpressions.com>
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> click here
> <http://rd.yahoo.com/SIG=12ckc0hds/M=268585.4464812.5643763.1261774/D=egro
> upweb/S=1705031972:HM/EXP=1075409858/A=1950447/R=0/*http://ashnin.com/clk/
> muryutaitakenattogyo?YH=4464812&yhad=1950447>
> <http://us.adserver.yahoo.com/l?M=268585.4464812.5643763.1261774/D=egroupm
> ail/S=:HM/A=1950447/rand=762828540>
>   _____
> *	To visit your group on the web, go to:
> <http://groups.yahoo.com/group/DTXpress/>
> *	To unsubscribe from this group, send an email to:
> <mailto:DTXpress-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> *	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/>.
> ________________________________________________________________________
> This email has been scanned for all viruses by the MessageLabs Email
> Security System. For more information on a proactive email security
> service working around the clock, around the globe, visit
> <http://www.messagelabs.com>
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
2004-01-29 by gollywillickers
hi Scott.
i am in the NY area and i'm in a similar situation.
i will be building a shock absorbing floor riser for myself and one for a friend
who owns a DTXpress - for whom i've been doing some recording.
i've been working on several different designs. the design i'm leaning toward
for the current riser is based on essentially the same principals as the Tennis
ball platform but is implemented a bit differently.
if you'd be interested in having me build one for you while i'm doing these
others - maybe we could work something out.
i've designed and built many things over the years, professionally. this will be
done right. and i do have the design directive in mind of affordability and
portability that my own city apartment demands.
anyway, i just thought i'd mention it.
--- In DTXpress@yahoogroups.com, "sjr41" <sjr41@c...> wrote:
> Hi Ed,
> Thanks!
> Scott
> platforms
> for
> move
> big
> > all
> > > the time! :-)
> > > thoughts?
> off!)?
> > Chris,
> > you IN THE UK.
> > Ed
2004-01-29 by sjr41
Wow, thanks -- I apreciate the offer -- but I am glad to say not only
that it won't be necessary, but also that I have a different (&
cheaper & easier) idea for you (& others) to try before you start
building anything.
As I mentioned in my previous post, I am lucky in that my neighbor
has been surprisingly good about trying to "work together to find a
solution" to the noise situation.  So, last night, when I went to
tell her that I was looking into the tennis ball deal and/or the Iso-
Floor thing, she said she'd hate for me to go to all that trouble &
expense, & suggested that we try the following idea...
First, let me say that I followed up on OGD's suggestion that I check
on whether it was the whole kit or just the pedals that was bothering
her, & she verified that it was really just the kick drum.
So, she gave me an old closed-cell foam sleeping pad (the kind used
for camping -- but this one was particularly dense & 15 mm thick),
and I just cut a piece that were slightly larger than my kick pedal &
placed it underneath.  To keep my feet level, I did the same thing
for the HH pedal.  Then I started playing at normal volume and...
voila!  She said it made a HUGE difference (no more dish rattling),
and that she could definitely live with that amount of noise.
I was a little worried that the foam would make the pedals
feel "squishy" -- and it did take a little getting used to at first --
 but it really wasn't too big of a difference in feel, so that was
good -- and my problem was solved!!!
Later in the evening, I took it one step further by cutting 4 small
squares (about 4" x 4") and putting one under each foot of the DTX
rack -- this had the double bonus of bringing the whole kit an equal
distance off the ground and further reducing vibrations for my
neighbor below -- and did not seem to make the DTX feel shaky or
unstable at all.
The best part of all of this (beside being cheap & easy) is that it
takes up NO addidtional space, like a riser platform or Iso-Floor
squares would have.
SO, I heartily encourage folks to try this first before investing in
other methods.  if anyone wants mor info about the particular brand
foam pad I used, I'll be happy to share it -- but I think any dense
closed-cell foam sleeping pad should work.  Hell, I've actually got a
bunch left over, so if you're interested in getting some, maybe we
can work something out as well..
Anyway -- good luck & happy (vibration-reduced) drumming!
Scott
--- In DTXpress@yahoogroups.com, "gollywillickers"
<gollywillickers@y...> wrote:
> hi Scott.
for a friend
leaning toward
as the Tennis
doing these
this will be
affordability and
> > Hi Ed,
really
Any
whether
squares
level),
kit &
with
on
> > Thanks!
> > Scott
> > platforms
issue
> > for
I
> > move
was
> > big
it
> > > all
> > > > the time! :-)
stool
> > > > thoughts?
> > off!)?
> > > Chris,
seems to
help to
> > > you IN THE UK.
> > > Ed
Re: [DTXpress] Re: Tennis ball platform / Clearsonic Iso-Floor
2004-01-30 by Ken Weygandt
You can get this stuff here in the states in Home Depot Or Lowe's. It's pink or blue foam insulation board. It's very dense and it comes in a 2' x 8' x 1" or 2" thick slab. Not expensive either.
Ken
Sent: Thursday, January 29, 2004 5:30 PM
building anything.
unstable at all.
squares would have.
Scott
wrote:
> hi Scott.
for a friend
leaning toward
>; for the current riser is based on essentially the same principals
as the Tennis
doing these
this will be
affordability and
> --- In DTXpress@yahoogroups.com, "sjr41" wrote:
> > Hi Ed,
really
Any
whether
squares
level),
kit &
with
on
> > Thanks!
> > Scott
wrote:
> > > --- In DTXpress@yahoogroups.com, "Chris" wrote:
>; > > > I'm considering building one of the tennis ball isolation
> > platforms
issue
> > for
I
> > move
was
> > big
it
> > > all
> > > > the time! :-)
stool
> > > > thoughts?
> >; > > Also, has anyone actually built such a platform (stool on or
> > off!)?
> > > Chris,
seems to
> > > have had success. ; Maybe you can contact him privately. Another
help to
> > > you IN THE UK.
> > > Ed
Yahoo! Groups Links
Re: Tennis ball platform / Clearsonic Iso-Floor/Foam Insulation Board
2004-01-30 by emf
We ought to make a permanent note of this method. If it works, at
least in some cases, and is cost-effective, people should be able to
find out about closed-cell foam sleeping pads just as quickly as they
do about the DIY platform and Iso-floor. Vern, how about a link to
Iso-floor at DTXpressions and an outline of the foam method in Tips
and Tricks?
Ed
2004-01-30 by sjr41
Not being much of a Home Depot guy, I have not heard of the foam
board mentioned below, but if it's thick & dense it should probably
work fine (as long as it can be cut to shape as needed).
Being a pretty avid backpacker, I have actually checked out a number
of sleeping pad options over the years, which leads me to point out
one thing to keep in mind if you are shopping for one to use as drum
pads -- most of the pads for sale through outdoor retailers are
designed to be lightweight (for backpacking), and thus are not as
thick or dense as the one I got from my neighbor.  Like I said, this
thing is thick (15mm), heavy, spongy & dense.  This means that it
would be terrible would backpacking, but these same traits would seem
to make it better for our purposes than most of the pads that are
available from outdoor gear places.  (Not that other kinds wouldn't
work well -- I just think this stuff might be even better).
So, to help out others in the group, I tried to find the stuff I got
online, but sisnce it's made by a French company, I had some trouble
finding anything in English -- but here's what I found.
The pad I used is madce by a company called Domyos, and it is model #
TG 400.  Domyos is apparently owned by another company called
Decathlon.  The website (www.decathlon.fr) is in French, but here a
link to the Google-translated version:
http://translate.google.com/translate?
hl=en&sl=fr&u=http://www.decathlon.fr/Magasin/tableau_comparatif.asp%
3Fint_DeptId%3D2274&prev=/search%3Fq%3Ddomyos%2BTG%2B400%26hl%3Den%
26lr%3D%26ie%3DUTF-8%26oe%3DUTF-8%26sa%3DG
I found the US version of the website (http://www.decathlon-
usa.com/), but it did not have anything about the TG 400 pad.  I sent
an email requesting info on where it can be purchased, what it costs,
etc, & now I am waiting for a response...
I'll keep y'all posted.
Scott
Lowe's.
comes
to
they
> and Tricks?
> Ed
2004-01-30 by emf
got
trouble
sent
costs,
Scott,
That's great. Wouldn't Decathlon love to know that their product may
have a side benefit for electronic drummers? If we find that it
works, maybe they'd even modestly adapt it and market it as such.
Then maybe for announcing its availability, DTXpress Group members
would get a discount, stock options, franchises. . . . All right, I'm
jumping the gun a little.
Ed
Re: [DTXpress] Re: Tennis ball platform / Clearsonic Iso-Floor/Foam Insulation Board
2004-01-30 by Vernon Graner
Do you have a summary of the links that I need to place? just email them
to me and I'll put them up. :)
Vern
Vern Graner CNE/CNA/SSE    | "If the network is down, then you're
Senior Systems Engineer    | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com        | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" VLG
> and Tricks?
> Ed
> Your use of Yahoo! Groups is subject to:
