Configuring HH controller for double bass
Re: [DTXpress] Configuring HH controller for double bass
2004-01-24 by the Sonic Energy Authority
Hello Ken.
1) We will need to be in Voice Edit Mode.
2) Make a note of all the settings of your kick drum sound.
3) Make a note of all the settings for your closed hi-hat sound.
4) Enter all the settings of your kick drum sound into the pedal trigger
(hit the hi-hat pad, then close the foot pedal - it would normally produce
the sound of the hi-hat closing - darn clever if you ask me)
5) Enter all the settings of your closed hi-hat sound into your open hi-hat
sound.
NB - All settings means settings from both layers if used.
I've a single kit with a double kick setting, I only use one because I'm not
very good at it - make that piss poor in fact.
My brain can't seem to cope with trying to separate each limb.
I can double pedal, but my left & right arm want to copy what my legs are
doing.
So I just stick to a normal set-up most of the time.
the Sonic Energy Authority - a sound investment
Re: Configuring HH controller for double bass
2004-01-25 by Chris
--- In DTXpress@yahoogroups.com, "boomer535" <boomer17@a...> wrote:
> I have a DTXpress kit and would like to know if there is a way to
> configure the HH controller as a second bass drum.
- Press 'voice' to enter voice edit mode.
- Give the kick pad a hit to select that pad/voice.
- Page down to 'CopyTo IN=' and use the value buttons to
select 'footCl'.
- Press 'Save/Ent' twice to save that setting and away you go.
I hope that works for you.
Chris
2004-01-25 by boomer535
Chris,
Thanks for the proceedure. Doesn't get any easier than that. Much
better than writing down all the parameters then entering them into
the footCl one at a time.
Ken
> select 'footCl'.
> Chris
