tracks without drums?
2004-02-15 by kirkmangraham2000
Does anyone know of any albums you can buy without the drum track?
Or any place to get MIDI files without the drums?
Cheers
Re: tracks without drums?
2004-02-15 by Chris
--- In DTXpress@yahoogroups.com, "kirkmangraham2000"
There is (I believe) a series of CDs with books called "In Session
With..." which feature two versions of the featured tracks; one with
drums and one without.
As for MIDI files, they can all be played back without drums by
muting the relevant track in a sequencer.  If you don't have one
there may be a freeware program to play back MIDI files that allows
muting of individual tracks.  I've just had a quick look but I can't
find one!
Chris
2004-02-15 by Chris
allows
can't
> find one!
...and then I do!  The following program seems to do what you need.
It's vanBasco's Karaoke Player.
http://tinyurl.com/3x6gj
Chris
2004-02-16 by ozteevan
If you have your module hooked up to your PC using a standard midi
cable then you can play the midi files back using a player such as
WinAmp. (I have not tried MediaPlayer but it may also have the
following feature.) Check the midi options on the player and see if
you can select the output device. If you select the sound card then
the sound will start to be generated on the modules synth. You can
then use the module to drop out the drum/rhythm track.
This approach allows you to play along with just about any midi file.
But...if you would prefer a small selection already muted then try
<http://home.texoma.net/~docdoc1/jamindex.htm>
Roger
Re: [DTXpress] Re: tracks without drums?
2004-02-16 by Ken
Is there a way I can convert these midi files to wav or mp3 format so I can put them on a CD?
Ken
Sent: Monday, February 16, 2004 2:43 AM
Subject: [DTXpress] Re: tracks without drums?
Roger
Community email addresses:
Post message: DTXpress@yahoogroups.com
Subscribe: DTXpress-subscribe@...m
Unsubscribe: DTXpress-unsubscribe@yahoogroups.com
List owner: DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
http://www.dtxpressions.com
2004-02-17 by Vernon Graner
In simplest terms:
MIDI files contain the note on/off data for a song. The MIDI file needs
an instrument to control in order to make sound. If you want to play a
MIDI file, most newer Windows computers will have a GM (Or General MIDI)
instrument set that can be the instrument the MIDI file is sent to. You
would then record the output of the MIDI instrument. Some soundcards even
have wavetable samples internally that you may send the MIDI data to to
create more realistic sound than "FM Synthesis" systems included in older
versions of windows and with many older sound cards. OF course, one of
the better GM instruments you already own is probably the DTXpress
module. :)
Now, when it comes down to precise instructions on how to get the MIDI
files you have recorded as MP3 or WAV files, this will be dependent upon
the equipment at your disposal. However, I'll take a stab at it here:
1) Open the MIDI file with Winamp (or windows media player)
2) Set the MIDI output to MPU401 MIDI interface
3) Press play and listen to the DTXpress module and make sure it is
playing  what you expect/want the MIDI file to sound like
4) Run the R/L output from the DTXPress to the LINE IN on your sound card.
5) Open your sound recorder of choice (cool edit, soundforge, even Sound
Recorder will work)
6) Record and save as a wave file then convert to MP3 if you like..
Hope that helps... :)
Vern
Vern Graner CNE/CNA/SSE    | "If the network is down, then you're
Senior Systems Engineer    | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com        | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" \ufffdVLG
2004-02-17 by Ken
Actually, I was referring to those MIDI files that are available on that web site someone else pointed us to. I found a way. As you say, just play them through the Windoze Media Player and then start recording in MP3 format with a recorder. Those track come without the drum sound.
Ken
Sent: Tuesday, February 17, 2004 10:59 AM
Subject: Re: [DTXpress] Re: tracks without drums?
In simplest terms:
module. :)
Recorder will work)
Vern
Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
Subscribe: ; DTXpress-subscribe@yahoogroups.com
