Réf. : Re: [DTXpress] Re: tracks without drums?
2004-02-17 by isabelle.dubaelle
please editor song exist for the dtxpress????
what your name ????
thanx i am french
-------Message original-------
Date : 02/17/04 16:59:17
Sujet : Re: [DTXpress] Re: tracks without drums?
Ken said:
> Is there a way I can convert these midi files to wav or mp3 format so I
> can put them on a CD?
In simplest terms:
MIDI files contain the note on/off data for a song. The MIDI file needs
an instrument to control in order to make sound. If you want to play a
MIDI file, most newer Windows computers will have a GM (Or General MIDI)
instrument set that can be the instrument the MIDI file is sent to. You
would then record the output of the MIDI instrument. Some soundcards even
have wavetable samples internally that you may send the MIDI data to to
create more realistic sound than "FM Synthesis" systems included in older
versions of windows and with many older sound cards. OF course, one of
the better GM instruments you already own is probably the DTXpress
module. :)
Now, when it comes down to precise instructions on how to get the MIDI
files you have recorded as MP3 or WAV files, this will be dependent upon
the equipment at your disposal. However, I'll take a stab at it here:
1) Open the MIDI file with Winamp (or windows media player)
2) Set the MIDI output to MPU401 MIDI interface
3) Press play and listen to the DTXpress module and make sure it is
playing what you expect/want the MIDI file to sound like
4) Run the R/L output from the DTXPress to the LINE IN on your sound card.
5) Open your sound recorder of choice (cool edit, soundforge, even Sound
Recorder will work)
6) Record and save as a wave file then convert to MP3 if you like..
Hope that helps... :)
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
Community email addresses:
Post message: DTXpress@yahoogroups.com
Subscribe: DTXpress-subscribe@yahoogroups.com
Unsubscribe: DTXpress-unsubscribe@yahoogroups.com
List owner: DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
http://www.dtxpressions.com
2004-02-17 by emf
--- In DTXpress@yahoogroups.com, "isabelle.dubaelle"
> what your name ????
>     thanx i am french
Isabelle,
Bienvenue. Ecrivez en francais. Peut-etre quelqu'un te comprendrait.
Pardonnez ma francais.
Ed
2004-02-17 by Brett
Bonjour là. Il y a un certain nombre de différentes manières de
communiquer avec vous, ainsi si vous préférez, nous pouvons
communiquer en français à l'aide d'un traducteur. Dites-nous votre
needs/wants, et nous ferons notre meilleur pour vous donner une main.
Brett
> what your name ????
>     thanx i am french
> De : DTXpress@yahoogroups.com
> A : DTXpress@yahoogroups.com
format so I
> In simplest terms:
needs
play a
MIDI)
You
soundcards even
to to
older
of
> module. :)
MIDI
upon
here:
sound card.
Sound
> Recorder will work)
> Vern
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/DTXpress/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
re bonjour merci
ben a vrai dire je voulais savoir s'il existais un programme editeur de son pour la yamaha dtxpress et si possible savoir quels sont les logiciels qui me serait utiles afin de tirer au mieux des avantanges de mon modules
merci bcp
David
Date : 02/17/04 20:21:50
Sujet : Réf. : Re: [DTXpress] Re: tracks without drums?
Brett
> what your name ????
> thanx i am french
format so I
> In simplest terms:
needs
play a
MIDI)
You
soundcards even
to to
older
of
> module. :)
MIDI
upon
here:
sound card.
Sound
> Recorder will work)
> Vern
Re: Réf. : Re: [DTXpress] Re: tracks without drums?
2004-02-17 by Brett
Unfortunately, le Yamaha le DTX sont capable de l'\ufffdvolution ou changement de quelque fa\ufffdon. Je ne peux pas comprendre votre question correctement, mais il n'y a pas aucune application de logiciel qui peut modifier ou change les bruits produits par le module. Ce que le module a en ce qui concerne des bruits soyez, unfortunately, unchangable. Ils peuvent seulement \ufffdtre chang\ufffds par les modules pour poss\ufffdder des param\ufffdtres sains. J'esp\ufffdre que j'ai r\ufffdpondu \ufffd votre question. Encore, je ne suis pas s\ufffdr que je comprends la question compl\ufffdtement, mais je suis dispos\ufffd \ufffd essayer encore si ceci ne vous a pas aid\ufffd du tout.
Brett
"isabelle.dubaelle" <isabelle.dubaelle@...> wrote: FLAVOR00-NONE-0000-0000-0000000000004.0; re bonjour merci
      merci bcp
    David
Sujet : R\ufffdf. : Re: [DTXpress] Re: tracks without drums?
Bonjour l\ufffd. Il y a un certain nombre de diff\ufffdrentes mani\ufffdres de
communiquer avec vous, ainsi si vous pr\ufffdf\ufffdrez, nous pouvons
communiquer en fran\ufffdais \ufffd l'aide d'un traducteur. Dites-nous votre
Brett
> what your name ????
>     thanx i am french
format so I
> In simplest terms:
needs
play a
MIDI)
You
soundcards even
to to
older
of
> module. :)
MIDI
upon
here:
sound card.
Sound
> Recorder will work)
> Vern
> Austin Office 512 328-8947 | you, so why are we paying you?" \ufffdVLG
Yahoo! Groups SponsorADVERTISEMENT
Click Here
Yahoo! Groups Links
Vote Quimby!
2004-02-17 by Brett
ammendment : le bruit de DTX n'est pas capable de l'modification par une source ext\ufffdrieure de logiciel
      merci bcp
    David
Brett
> what your name ????
>     thanx i am french
format so I
> In simplest terms:
needs
play a
MIDI)
You
soundcards even
to to
older
of
> module. :)
MIDI
upon
here:
sound card.
Sound
> Recorder will work)
> Vern
Click Here
Yahoo! Groups Links
Vote Quimby!
