DTXPRESS I and DTXPRESS II
2004-03-04 by rtmt91drummer
I was wondering what the differnces are between the I and II modules.
Does it have better cymbal sounds... or does any one have a good
custom cymbal sound in the dtx1 that really has a bright sound that
projects well. It seems at times mine are not loud enough when
playing. Would it be worth the money to upgrade to the II if I was to
find the right price for a used one?
Also I have the DTXPRESS I module a pads. But I am wanting to upgrade
to a larger mesh head pad for the snare. Any sugestions?  pintech?
hart?  build my own?
Re: DTXPRESS I and DTXPRESS II
2004-03-04 by emf
--- In DTXpress@yahoogroups.com, "rtmt91drummer" <rtmt91drummer@y...>
modules.
to
So far as I can tell, and remember, the only differences between the
I and II modules were exterior color and the latter's ability to
handle the three-sound snare (and cymbal). The cymbal sounds per se
are the same, or basically the same. I had a couple of bright ride
and crash cymbal sounds on the I that I liked, but I don't remember
them coming to life until I used other pads with the module. If no
one else has the voice names handy, I'll rummage for mine.
One way to get your cymbal sounds louder would be to turn everything
else down so that when you amplify, the cymbals cut through better.
When the volumes of all the inputs are maxed out, the cymbals and hi
hat seem to get shortchanged. I don't think that moving from the I to
the II would get you much, especially if you're thinking of going
with mesh. Moving to the III, however, would get you new cymbal
sounds, which apparently are better.
upgrade
> hart?  build my own?
You can always build your own if you have either an acoustic snare
that you're willing to sacrifice or are willing to scrounge or buy
cheap materials. The electronicdrums site is good for step by step
instructions. DIY will definitely save you money, but resale value,
if not looks, can suffer, if that matters to you.
The Yamaha modules have had trouble mating effectively with Hart
meshes in the past; the signal is too attenuated. Hart, unlike other
companies, has never seemed particularly interested in courting
Yamaha users. I certainly wouldn't buy a Hart mesh sight-unseen (or
sound-unheard). The Pintech ConcertCasts, which I recommend for a
number of reasons, make ample noise through Yamaha electronics--some
say too much. If you have a light touch, the minimum gain on the
Pintechs, as currently constituted, may seem too loud. If so,
inserting a 200k pot between input and pad--either yourself or via a
cable with its own pot(Guyatone interconnects, for example)--seems to
satisfy those who have difficulty. Brian LaRue mentioned the
possibility that Pintech might consider adding a sensitivity
adjustment to the pads themselves. If he eventually does so, and you
buy yours now, you might be able to get it retrofitted with the knob
later, but I'm getting way ahead of myself.
Ed
