DTXpressIII Problem
2004-04-25 by markalias
Just got my module back from the tech Yamaha had my local music store send it to. He claims not to be able to re-create the problem I'm having, and I wondered if anyone here has a similar issue with the DTX III. I have two keyboards & the DTX (Special) pads as controllers, and a number of sound modules hooked up to a mixer. Two problems: 1. The only sound module I need to add gain to is the DTX III. For some reason, it has the weakest signal of all my modules. 2. This is the wierd one, which I probably wouldn't even hear if not for #1. If I play either of the keyboards, which send MIDI note messages to the DTX, I can hear clicking coming out of the DTX's audio channel even if the DTX is turned off. I've isolated this to the DTX itself. If I connect a keyboard's MIDI out to the DTX's MIDI in, turn off the DTX, and play the keyboard with Local Off and all other mixer channels muted, I can hear faint clicks coming out of the DTX's audio outputs in response to the Note On messages coming into its MIDI in. Unplug the MIDI in from the DTX, or the audio outs, and the problem goes away. Anyone else have these issues with the DTX III? Any advice now that the repair guy can't hear this? Thanks.
