Cross Talk & multiple modules
2004-06-18 by Timothy & Jessamyn
Can anyone give me advice on a couple of things.  I have a dtxpress
II and I've added another module, (a used Alesis D4) and a few extra
pads.  I really don't know how to use the Alesis D4.  I didn't get a
manual but I downloaded one from the internet and there seems to be
some info missing.  I can't figure out how to assign a pad the voice
I want.  I tried doing it the way the dtxpress module works, but
obviously the D4 uses some other method.  Can anyone tell me what it
is?
Also, I'm getting cross talk between the modules.  I hit a pad
connected to the dtxpress, and and Alesis pad sounds as well, & vice
versa.  What's the best way to control that?
Last question: At church, I play an older dtxpress.  We've ordred a
couple of extra pads and another used dtxpress module in order to
have a few more drum voices availble.  I'm going to have to mount the
new pads on the same arm(s) as the existing pads from the existing
module.  I expect I'm going to have some crosstalk issues there too.
Any advice to head off that problem?
RE: [DTXpress] Cross Talk & multiple modules
2004-06-18 by rdamon@mckinney-usa.com
Tim,
I can't answer the Alesis question, as I have never worked with one.
The module question I can answer. If you go into the photo gallery you will
see that my kit has three modules, and alot of pads tightly pack to
together. The only crosstalk that is an issue on the kit is when I hit the
barpad on the right side of the kit too hard, otherwise, medium to light
hits and it's fine.
There are several things that I did.
One was to isolate the pads in groups and connect them to a module. All of
the pads on the left rack tie to module 1, the center rack pads tie to
module 2 and the right side rack tie to module 3.
The second thing I did was replace all of the cymbal arm rack clamps. I
replaced them with Gilbrator Road Series clamps. The clamps open up wider
than the cymbal arm, unlike the standard Yamaha cymbal clamps. I then took a
heavy piece of rubber and wrapped it around the cymbal arm tube and then
placed that in the new clamps. The rubber was from a older washing machine
drain holes, very heavy and very sturdy. The rubber isolates the cymbal arm
from the clamp.
Other folks here have filled the rack tubing with insulating foam, buy I
have had needed to do that, but it does help.
Hope this helps.
OGD-OldGuyDrummer
   _____
Sent: Friday, June 18, 2004 10:02 AM
To: DTXpress@yahoogroups.com
Subject: [DTXpress] Cross Talk & multiple modules
is?
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
