RE: [DTXpress] Using a foot pedal as a control to dec value of dr um kit
2004-06-29 by rdamon@mckinney-usa.com
Nancy, I just posted a response on www.dtxpressions.com <http://www.dtxpressions.com> to a question of inc/dec the kit. It is under Misc. Discussions/ changing your kit mid-song". That is the sister site to this one. You can use any pad, but I am not sure the hihat pedal will work unless you are willing to giving the hihat input all together. One way is to get a BP80 barpad, which has two trigger pads, using one for Increment and the other for Decrement. You can also use a single pad, but then you would be limited in what you can do. Hold on, before I completely repeat what I said there, let me just post it here. To set a pad permanently to an increment or decrement pad, that doesn't change assignment even when you change kit numbers go to the trigger setup menus. [shift-trig] Page down to the menu that looks like this: TRIG Common IncIn=4 DecIn= 5 The numbers "4" indicates you want to select pad input no. 4 for the Increment pad and "5" indicates you want to select pad input no. 5 for the Decrement pad. The numbers can be --(none), 1-10. ================================ If you just want to use a pad as an increment/decrement pad for one or two kits, then you use the Drum Kit edit mode: In this example, let's assume that input 9 will increment by one when struck in user kit no. 60 and input 9 will also be used to decrement by one in kit 61. Thus by striking the input pad that is connected to input 9 when kit 60 is active the kit number will change to kit 61. When the active kit is set to 61, striking the pad connected to input 9 will decrement to kit 60. Start by going into the voice edit mode for the specific pad you want to setup, in this case input 9. First, go to the user kit 60 (just an example). Press the voice button, page down until you get this screen: KIT IN=Pad 9 Func= normal Tab through the Function selections until you get: KIT IN=Pad 9 Func= inc drumkit This assigns pad 9 as an increment function only when you have kit 60 selected as the active kit. Press the SAVE/ENT button twice, kit 60 has now been setup. Don't worry about any of the other voice settings for Pad 9, because they have now been disabled when you are in kit 60. Second, go to the user kit 61 (just an example). Press the voice button, page down until you get this screen: KIT IN=Pad 9 Func= normal Tab through the Function selections until you get: KIT IN=Pad 9 Func= dec drumkit This assigns pad 9 as an decrement function only when you have kit 61 selected as the active kit. Press the SAVE/ENT button twice, kit 61 has now been setup. Don't worry about any of the other voice settings for Pad 9, because they have now been disabled when you are in kit 61. Now when you are in kit 60 and you strike pad 9 the kit will increment, when you are in kit 61 and you strike pad the kit will decrement. Remeber you can setup any combination, for example you can set it up to start at kit 60, then goes to 61, then to 62, then to 63... so that kit 60 can be the first song on the play list, 62 can be the second song on the play list and so on. Thus you can set up to 32 kits for 32 songs, one kit per song in the play list. If you use the same kit for songs 1,3,7,10,22,23,24, just setup the common kit settings in the first kit and then copy it to the other kits. Also if you save the drumkit as the song name or song types, you can easily see if you have the right kit selected. You can setup user kits 48, 49, 50, 51, 52 as say "master" kit types and then when you know your song list, you can just copy these to the appropriate user kits, from 53 and higher. Hope this helps. OGD _____
From: Nancy Solomon Sent: Tuesday, June 29, 2004 12:02 AM To: DTXpress@yahoogroups.com Subject: [DTXpress] Using a foot pedal as a control to dec value of drum kit Hello to anyone out there who can answer this question: I am wondering if I can program the brain of my dtxpressII so that it is possible to use an extra hihat pedal as a control to be able to switch from one kit sound to another and back again. Is this what the Func parameter can do if it is set to "dec drumkit"? If yes than how would I program such a thing? Would it be done through the Voice Edit Mode? Could somebody give me a step by step procedure to follow. I may have misunderstood and overestimated the capability of this module. It would be quite handy to be able to switch between drum kit sounds even in one direction. I am assuming that going "inc drum kit" would require another input source. PLeas advise, and thank you for your help Webc1958 ************************************************************************** The information transmitted herewith is sensitive information intended only for use to the individual or entity to which it is addressed. If the reader of this message is not the intended recipient, you are hereby notified that any review, retransmission, dissemination, distribution, copying or other use of, or taking of any action in reliance upon, this information is strictly prohibited. If you have received this communication in error, please contact the sender and delete the material from your computer. ______________________________________________________________________ This email has been scanned by the MessageLabs Email Security System. For more information please visit http://www.messagelabs.com/email ______________________________________________________________________
