Horizontal lines in print
2010-04-13 by mike-theprint@waspfactory.org
Hi folks,
I've been using UT14 in my 1400 printer for a little while now and the
results are promising. But I have a problem.
I loaded the inks and printed a purge pattern on a scratch sheet of
Epson Ultra Premium Photo Paper Luster. That was the first print I did
with them (except for a nozzle check and maybe head alignment, I think -
I don't quite remember). All the bands look great, except for light
magenta: That one started out nice and smooth, and then after a quarter
inch of printing, developed some horizonal banding, which has persisted
in every print since, despited repeated head cleanings.
To illustrate, I took a picture:
http://waspfactory.org/~mike/pics/lines-in-purge.jpg
(Yeah, there are a couple specks on the sensor.)
The squiggly white line there concerns me a bit: I wonder if the print
head scraped something off the paper, and that's what's causing my
problems. But nozzle checks print without any gaps, and head alignments
work fine.
Yesterday I tried the Windex cleaning solution described here:
http://www.digitsmith.com/epson-1400-horizontal-lines-print-11502.html
but that hasn't helped.
Anybody have any suggestions?
  | Mike Acar |                                | mike at waspfactory dot org |
Re: Horizontal lines in print
2010-04-13 by pr_roark
mike-theprint@... wrote:
> I've been using UT14 in my 1400 printer ... have a problem.
> ... a purge pattern on a ... Epson Ultra Premium Photo Paper Luster. >... light magenta: ... started out nice and smooth, and then
> after a quarter inch of printing, developed some horizonal
> http://waspfactory.org/~mike/pics/lines-in-purge.jpg  ...
> The squiggly white line there concerns me a bit: ...
Do you have a dog?  That looks like the Retriever hair that wrecks havoc on my printers (though usually not a clog).  Try some bias tape soaked in Windex pulled back and forth under the head.  Also, try to wipe off the wiper blade.
Re: [Digital BW] Re: Horizontal lines in print
2010-04-13 by Mark Savoia
Isn't bias tape too rough, acts like sandpaper, could damage head,
leaves fibers?
Mark
http://www.stillrivereditions.com
> Paul
> www.PaulRoark.com
> leaves fibers?
Good question.  I don't know.  I have not had any problem with fibers.  I probably have not had to do this enough to have damaged a head.  I switched away from paper towels, thinking they had wood fibers in them and would leave debris.  I suppose 100% cotton strips would be the best bet -- not sure if there are any pre-made ones that would work.
> > Paul
> > www.PaulRoark.com
Scanner wipes work great. Lintless.
Mark
>> leaves fibers?
> that would work.
> Paul
> www.PaulRoark.com
Heh, no, I don't. Maybe time for you to set up a clean room? :)
But, point taken.
Ok. I haven't done any surgery on the printer yet, so I'm not sure how
to identify the wiper blade. Got a reference to a diagram or maybe
video? I did a little Googling but didn't find anything obviously
relevant.
Mark Savoia suggested scanner wipes, which I think I'll try instead.
