OT: b&w negative scanning issue
2010-05-10 by Michael
I hope this isn't too far off topic. I'm scanning some 4x5 b&w negs that I'm having mixed results with. The problem is with the subject which is low contrast landscape scenes with snow and trees/vegetation and an overcast sky. The tree bark is the darkest part of the scene and meters in the field at around zone 5 (incident) while the snow comes in 2-3 zones higher. The equipment I'm scanning with is an Epson 4870 with the film scanning setup for 4x5 negs. I'm also using Epson Scan. So, I do a preview scan and pull up the histogram; next I isolate the image with a marquee. I find the exposure pattern located entirely on the right side with the black point/white point limits at 150 & 240 and the midpoint at 1.50. The preview image is dark with the sliders pulled to these points. A completed scan with the black/white points set as described produces a dark, hard to evaluate image. The image also has a lot of pure black in the shadows with no detail. Opening the image in PS and pulling up another histogram, I find the image touching the black point but does not extend to the white point. However, a triangle/exclamation pt. has appeared next to the histogram and I clicked it to refresh the histogram. Now there is a one pixel high black line lying on the bottom border and extending out to the white point marker at 255. (I'm thinking this could be from dust on the negative during exposure and creating a clear spot on it.) Now I pull the white point slider down to the normal start of the white point of the histogram mountain (right side); the image snaps to life. But there is too much pure black in areas that should show some detail and no amount of fiddling can find detail in these areas. As I mentioned earlier, the tree trunks were the darkest part of the scene and metered around zone 5. So I'm thinking that these mid-grey areas are now showing up as the pure black due to my placement of the black point during scanning. (This is starting to make some sense as I write...) But we're not done. I do a second scan and this time place the midpoint slider, prior to final scanning, down where one would normally place the black slider and place that slider lower in the space between the left border and the start of the black end of the histogram - sort of in no-man's land. Opening in PS I now have much less pure black and the midtones are in a workable range. It's useable. Is the lesson to be learned this: when the original scene is very low contrast and the darkest point is equivalent to a mid-grey, scan the negative so the midpoint slider points to the lowest end of the histogram mountain? This seems to prevent the scanner from making these mid-grey areas from turning pure black. All comments and other ideas appreciated.
