speaking of humidity
2010-05-24 by faeofavalon
Hopefully someone can help here? I have been using Hahnemuhle's bamboo paper for some time now with no problems whatsoever. I am using it with Epson's r2400, rear-feed. The rear-feed is not taking it now and even after cleaning the rollers, I am still not having any  luck. I have tried a thinner paper and it seems to go through ok...any thoughts?
Thanks!
AnnMarie
www.annmarietornabene.net
Re: [Digital BW] speaking of humidity
2010-05-24 by Andrew Darlow
Hi Ann Marie:
Have you tried the normal top feed? With that option, you can pre-feed
by pressing the paper feed button for a moment and help nudge it in.
Hope that helps,
Andrew
Andrew Darlow
Editor, The Imaging Buffet
http://www.imagingbuffet.com
Author, 301 Inkjet Tips and Techniques:
An Essential Printing Resource for Photographers - http://www.inkjettips.com
and
Pet Photography 101:
Tips for Taking Better Photos of Your Dog or Cat - http://www.PhotoPetTips.com
> ok...any thoughts?
> Thanks!
> AnnMarie
2010-05-24 by Rudy Ternbach
Adjust paper thickness setting?
> Thanks!
> AnnMarie
Re:speaking of humidity
2010-05-25 by Jeff Phillips
AnnMarie,
For what it's worth, I have been using their Bamboo paper regularly for several years.  I use the 13x19 size on an Epson 7800 and until recently I never had any issues.  The last box that I bought in late April had unusually severe curling along the 19" sides, and when I attempt to print on it, the printer heads smash into the edges of the paper and thrash about, tearing the paper and spewing ink.
To successfully I print on it, I must manually de-curl the sheet by bending the sides in the opposite direction of the curl for 10 or 15 seconds before loading it into the printer.
This very well may be coincidence or due to other factors, but after seeing your posting I thought I'd add my experience in case there are others on the list who have had this problem recently (thus suggesting a possible Hahnemule QA problem)
Jeff
crowdspotting.blogspot.com
Re:speaking of humidity/ink spots
2010-05-26 by faeofavalon
Hey Jeff -
Thanks for the input. The 8.5 x 11 sheets I was having problems with, I had cut from 13 x 19 sheets so I thought that might be the problem. I put a cleaning sheet in and ran it through a few times and now at least I can get prints. I was thinking the recent humidity was swelling the paper, making it too thick to load as well.
Incidentally, have you ever had ink spots along the edges of the paper? Once in awhile I get that only on thicker paper like the bamboo and the epson cold press.
- AnnMarie
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jeff Phillips" <jeffjphillips@...> wrote:
> AnnMarie,
> Jeff
2010-05-27 by Lutsky, Berel
Inkspots on the edges are usually indications of "headstrikes " - the print head is actually contacting  the paper - humidity will often cause a bit of swelling of the edges and or curvature of the paper - two solutions - work in a humidity controlled environment - expensive, keep your paper in a humidity controlled environment - a little easier -  - OR try making prints with wider margins - this will keep the printhead over the paper most of the time - in the long run headstrikes are not good for the equipment - and are to be avoided - if you can adjust your platen gap do so -
Berel Lutsky
Re: speaking of humidity
2010-05-27 by zz_ir
AnnMarie,
On my 2400, I have found that when I am printing on Hahnemuhle's Photo Rag 308 or Duo, or on Epson's Velvet Fine Art papers, I can feed through the top feeder but have to nudge the paper as it loads.  I have no seen any loading problems with headstrikes with any of those papers using this technique.
I have not tried the Bamboo, but the PRD and VFA are similar in weight.
keithz
http://kzarts.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "faeofavalon" <faeofavalon@...> wrote:
> Thanks!
> AnnMarie
2010-05-29 by faeofavalon
Hey Keith -
That is how I load the bamboo. I push slightly down onto the sheet for the printer to grab. As for headstrikes..I am still unclear from Berel's explanation on how or what is causing it but it doesn't occur all the time, and is usually one tiny red spot on the edge of the paper...
Update - last time I printed, I WAS able to load the paper so I am thinking humidity is the culprit.
Thank you all!
AnnMarie
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "zz_ir" <keithz@...> wrote:
> AnnMarie,
> keithz
> http://kzarts.com
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "faeofavalon" <faeofavalon@> wrote:
> > Thanks!
> > AnnMarie
2010-05-29 by Iric S
Might the problem be due to either a different manufacturing tech technioque or a naturally occurring difference in the material used to manufacture the paper?  It might be worth contacting the manufacturer to find out.  If so, then this discussion becomes academic since it cannot be fixed.
Submitted for thought
Iric
> Hey Keith -
> Thank you all!
> AnnMarie
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "zz_ir" <keithz@> wrote:
> > AnnMarie,
> > keithz
> > http://kzarts.com
> > > Thanks!
> > > AnnMarie
