Sheets/Rolls for HPR Which is Worse?
2010-05-21 by Josh Hackney
I primarily use sheets in my 7800. HPR sheets have a strong desire to curl up toward the print head causing the potential for head strikes. Rolls on the other hand, if used with the built in cutter, produce dust that can clog nozzles. Buying roles, and cutting before inserting in the printer makes no sense to me, and manually cutting with scissors/knife/epson add-on cutter/other device after the print emerges is certainly possible, but not ideal. Is anybody doing production printing via rolls on HPR or another fine art paper and still using the built in cutter? Is the dust a long term reality or just a theory? Thanks. Josh [Non-text portions of this message have been removed]
