horstenj schreef:
> Thanks John.
> I already had downloaded Qimage. Indeed I can define any paper size.
> But as far as I have mastered it for now, I can only define SHEET
> sizes. I'm printing on ROLLS, so width is fixed but length is
> variable. My question is if I need to adapt the paper size (width AND
> length) for every print batch. Can't I tell Qimage that I'm printing
> on rolls and that it figures out itself what the length should be
> given the size of the image?
> Joost
Joost,
Qimage can't.
It has been discussed before in the Qimage forum but Mike didn't bring
that feature. It could be that the nesting structure needs to be
rewritten as the print page size is then no longer fixed.
It would be a nice feature, many RIPs have it.
If Qimage also got a hot folder system with the possibility to create
different hot folders based on the job/session recalls then that print
page fill feature would be even more helpful. Think about remote loading
of files and printing. Prints ready when you get home from a shooting
session. Not my kind of jobs though.
I have not tried this out: if you make the print page very long and you
shut Auto cutting off, compact nesting selected in Qimage, then it may
be possible to move the paper backward on the printer's panel menu after
the job and cut it then "manually" with the panel commando within the
original print page length. Creating a new leading edge for the next
job. The HP Z drivers allow that I think. Not the same of course as you
can not repeat that job after job without manual corrections.
Met vriendelijke groeten, Ernst
Try: http://tech.groups.yahoo.com/group/Wide_Inkjet_Printers/
| Dinkla Grafische Techniek |
| www.pigment-print.com |
| ( unvollendet ) |
