(no subject)
(no subject)
2010-08-08 by jwalpen
first set of cartridges still over half full but could not get it to print after
multiple cleanings so put in a new set -- same thing -- seem to remember making
the catridges go off where they rest and putting a cloth with windex there --
any help would be greatly appreciated as i need to print my artist's business
card -- and at 72 i am getting lower on time :-)
 jwpenland
828 280-9592
2200 not printing
2010-08-08 by Paul
> get it to print after multiple cleanings so put in a new set
> -- same thing --
> seem to remember making the catridges go off where they
One of the first and best tricks is to put Windex on the parking pad and let the printer sit overnight with the head in that Windex.  With the 2200 you can open the lid and reach the white gear over at the left.  Pull the top of that toward you to release the lock on the head assembly.  Now you can pull the head to the left to get at the parking pads.
While the head is freed up, you can also use some binding tape or other narrow strip of cloth or paper, soak it in Windex, lay it in the printer where the head goes over it, and then grab the ends of the bias tape and pull it back and forth across the underside of the head to clean off junk that might be caught on the surface of the head.
(If you're using third party inks, be sure the air inlets on the carts are opened.)
If all of the above fails, you can also buy cleaning carts.
Good luck.
