Sent: Tuesday, July 27, 2010 8:19 PM
Subject: Re: [Digital BW] Epson R280 does not work with transparency
> Ah that is a good idea. instead of finding where is the sensor I should
> tape an 8.5x11 backing sheet onto the transparency to block the light so
> the printer will think it is opaque material.
> Thanks,
> Phil
> mrjimbo wrote:
>> Phil,
>> I'm not familiar with the smaller printers at all.. On the large format
>> models you can go in and shut all that stuff off. Hopefully that is
>> possible
>> on these also.. If you using 8 1/2 x 11 just try a backing sheet..That
>> should get you out of the woods. As a thought.. I think I got it.. duh..
>> Go
>> to a fabric store.. ( we have JoAnns out here) they have a spray that
>> you
>> can use on a piece of paper or ??? this stuff is for quilters.. that will
>> turn the material into a sticky note sort of.. Then just lay your clear
>> material on that sheet and go for it.. bet that'll do it.. I use this
>> stuff
>> for all kinds of crazy things here.
>> jimbo
>> ----- Original Message -----
>> From: "Phil" <panmedia@...>
>> Sent: Tuesday, July 27, 2010 4:37 PM
>>> Thanks Jimbo. I think the printer paused when it detects I am using
>>> transparency material. Or it may use some sort of light to detect the
>>> page edge and the transparency material shows no edges to the light.
>>> I guess if I tape one side/edge of the transparency then it may be able
>>> to detect the edge of the sheet. But I am wonder which edge should be
>>> taped.
>>> Thanks,
>>> Phil
>>> mrjimbo wrote:
>>>> Phil,
>>>> The R280 uses Claria inks which is a dye based ink.. The transparency
>>>> material Epson sells is for Pigment based inks.. So they are not
>>>> supporting it with that printer. Just track down some transparency
>>>> material that is for Dye based inks..( HP has some) and go for it
>>>> ...you'll be just fine. I can't speak to how well it'll work for
>>>> digital negs....you may need to make a profile for it but I'd think
>>>> you'd be just fine..
>>>> jimbo
>>>> From: Phil
>>>> To: DigitalBlackandWhiteThePrint@yahoogroups.com
>>>> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>
>>>> Sent: Tuesday, July 27, 2010 3:02 PM
>>>> Subject: [Digital BW] Epson R280 does not work with transparency
>>>> According to Epson, R280 does not work with inkjet transparency.
>>>> Does anyone has a workaround on this? I am producing digital negatives
>>>> using transparencies and this limitation is a little strange.
>>>> Thanks,
>>>> Phil
>>>> [Non-text portions of this message have been removed]
>>> Please visit the Group Homepage to check the Files, and other resources
>>> as
>>> they are often being updated.
>>> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>>> If you wish to receive no emails or just a daily digest, or you wish to
>>> unsubscribe, please edit your Membership preferences by visiting this
>>> same
>>> page.
>>> Please follow these basic guidelines:
>>> - As threads develop, trim off excess portions of earlier messages to
>>> keep
>>> them short.
>>> - Good manners are required at all time. No personal attacks or flames.
>>> Hostile, aggressive or argumentative users may be removed from the
>>> membership without notice.
>>> - Keep your posts and threads related to the group topic of digital B&W
>>> printing. Users who persistently make off-topic posts may be removed
>>> from
>>> the membership.
>>> - By posting on this forum you agree to abide by the group rules and
>>> guidelines, and to abide by the actions and decisions of the group Owner
>>> and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files
>>> section:
>>> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>>> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
>>> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND
>>> \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
>>> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
>>> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
>>> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
>>> \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
>>> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
>>> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
>>> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
>>> (iii)
>>> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
>>> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
>>> PRINT YAHOO GROUP.
>>> Yahoo! Groups Links
>> as they are often being updated.
>> same page.
>> keep them short.
>> printing. Users who persistently make off-topic posts may be removed from
>> the membership.
>> section:
>> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
>> PRINT YAHOO GROUP.
>> Yahoo! Groups Links
> page.
> them short.
> the membership.
> section:
> PRINT YAHOO GROUP.
