"lenwk" <lenwk@...> wrote:
> You've stated that when switching from the Ultrachrome inkset to eboni or carbon-6, the Ultrachrome inks should be flushed from the printer.
Actually, it's MIS that says when switching from Ultrachrome to Eboni-6 flushing is required. My position is that one should listen to MIS with respect to their inks.
For Carbon-6, no flushing is required, as far as I know. I think MIS is concerned with something in the Eboni-6 dilution base that is not in the C6 base.
> As I've never flushed inks before, and will be using the dilution base in refillable carts, I'm assuming I just run a few cleaning cycles with that base through my R2400 until the waste is clear (I'm using an external waste tank). Is that sufficient?
I suspect it is more than enough.
