MIS Associates Inks Drying Problem
2010-08-24 by stthcl
Hello,
I am new to digital printing. I have an Epson 1400 which I have filled with MIS Assoc UT14 inks. I am using Kirkland Glossy, one of the recommended papers for this ink and for this printer. The problem is that the paper does not seem to absorb the ink. Even after 72+ hours of curing it can be easily wiped off with a swing of the finger. I have the black digits to prove it. I have spoken with MIS several times. They tell me that they have had good results with this paper and this ink. So, I am back to square one. I have several questions: 1. Has anyone else had a similar problem? 2. Should I give up on the glossy and resign myself to using matte paper? 3. Does MIS "misrepresent" its products? They seem like very nice folks and have a good reputation but the proof is in the results. Any help would be appreciated.
Re: [Digital BW] MIS Associates Inks Drying Problem
2010-08-24 by Michael King
I am guessing you are using the Eboni black ink when you shouldn't be on
glossy. This will happen if you are using the wrong print driver / approach.
Have you read Paul Roark's article on this printer/ink combo ?
http://www.paulroark.com/BW-Info/UT14.pdf  Are you sure you are using one of
the glossy printing approaches detailed in this doc? Paul is probably the
best person to help you with this.
Mike
On 24 August 2010 17:41, stthcl <stthcl@yahoo.com> wrote:
> Hello,
2010-08-24 by Sylvain
I'm using Eboni inks on a 1400 (Eb1400 inkset). i've tried them on a glossy paper, and they do not keep on the paper unless I put some Lumijet. So I agree with Michael: you might have Eboni ink on your kit that you should not use while printing on glossy.
my 2c
> on glossy. This will happen if you are using the wrong print driver /
> approach. Have you read Paul Roark's article on this printer/ink combo ?
> Are you sure you are using one of the glossy printing approaches detailed in this doc? Paul is probably
> the best person to help you with this.
> Mike
> .com> wrote:
> > Hello,
> of the recommended
Re: MIS Associates Inks Drying Problem
2010-08-24 by badger346
Hi
I use an Epson 1400 with the UT14 MIS inkset. I've previously made QTR profiles for Kirkland Glossy: C/LC & M/LM
Let me know if you would like a copy.
Jon
2010-08-25 by Paul
"stthcl" <stthcl@...> wrote:
> ... UT14 inks. ... Kirkland Glossy, ... the paper does not seem to absorb the ink. ...
See http://www.paulroark.com/BW-Info/UT14.pdf for my write-up of the inkset.  On page 7 I deal with printing on glossy paper.  You can use either the Epson driver or QTR to have the C & M inks print the 100% black.  The Eboni in the K position is for matte paper only.
