ut-14 icc printing problem
2010-12-12 by fogmarco
I'm using an epson 1400 with ut-14 ink set. I'm very happy of this choice! I have a problem that I can't solve if I try to print with icc solution (eveithing is OK if I use QTR or curve). If I print with an icc file created with qtr the 21 step image is cut exactly on 70%. The print is ok from 0 to 70%, total white from 70 to 100. Why my printer don't print nothing from 70 to 100? I try to use the icc file downloaded from paul roark site and the result is the some. Any idea? CS4 with windows vista 64 bit Thank you Marco
