help with 7500, please
2011-01-02 by Richard Vanek
I have loaded big MIS cartridges with ebony6 inks set. I needed to get rid
of color inks from printer so I had run few cleaning cycles and some ink
charges. I have not get any b&w inks only the color and very very soft, not
relly full intensity.
Next day morning I have found insk from half of my cartridges on the floor
under the printer. I removed the cartridges as it seems that ink is just
leaking further. Later after I have opened printer I noticed that ink leaked
from overflowed waste inks pads.
Interesting was that tube of LM, LC and Y going to right printer head are
now empty while tubes going to left print head, K,M,C are full.
I had open right side of printer and checked all pipes (all seems to be
connected well), than I clean all from ink.
I also disconnected pipes with damper from head ink intakes. There was no
ink in dampers for right head.
Not sure why ink leaked, what could be the problem?
How can get ink from tubes into the waste ink pad, without getting into head
and on paper?
I would really appetite any tips what should I clean, check or do in general
to make my printer running.
I bough printer second hand and it was not used for some time.
I need to add little info from the beginning:
Before transport there was ink in printer, very little. We didn't do any
special procedure for transporting printer (in car for few dozen
kilometers).
When I unpacked and install home, all cartridges were almost empty. I bough
some new before I went to travel or  week. after week (printer was not
turned on) new cartridges was empty.
Thanks for your help!
Richard Vanek
portfolio: www.richard-vanek.eu
twitter: http://twitter.com/richo_67
facebook: http://www.facebook.com/pages/Richard-Vanek/142576177492
Re: help with 7500, please
2011-01-02 by Paul
> I needed to get rid of color inks from printer so I had
> run few cleaning cycles and some ink charges.
There is a procedure for preparing the printer for transport that drains the lines.  Then doing an initial fill usually gets most of the color out.  I may have needed to do these steps twice with my old 7500.
> ... ink leaked from overflowed waste inks pads.
I found cotton stuffing for chair cushions made a good & cheap substitute for the Epson material.
> printer head are now empty while tubes going to left print
Did the printer have a good nozzle check before it was loaded?
> ... There was no ink in dampers for right head.
I forget if that printer has 2 separate heads and pumps.  If so, the one for the light inks may be broken.
Both are risky with these old printers.  It think their value is about $0 now.  (I gave mine away.)
Even if you get it running. agitating the Eboni/Carbon-6 could be a problem with OEM type carts.  The rubber seals of the 7500 carts will start to leak if the printer carts are taken out for agitation too often.  The 7600 and newer printers have much more robust valves that can tolerate the agitation.
On the positive side, the big old drops of the 7500 can make a very neutral -- even cool -- carbon print on Premier Art Smooth BW paper.
Re: [Digital BW] Re: help with 7500, please
Dear Paul,
I wonder why the inks leaked.
Before transfer I have no possibility to do nozzle check so I do not know.
After the transfer I was not able to do it as one ink was empty.
When I replace empty cartridge with new than nozzles where fine.
Now I have printer open and I wonder what I should check or clean more
before I put new ink in.
Thanks for tip with cotton stuffing. I just washed the old ones, liter and
liters water are gone now :-(
Richard Vanek
2011-01-02 by Paul
Richard,
I was not sure if it was from the carts or the waste ink tray overflowing.
That's a good sign.
> clean more before I put new ink in.
Be sure the tubes that go from the parking stations to the pump to the waste ink tray are all in good shape and connected.
I'm definitely not an expert printer technician.  You might find more expertise on the Epson Wide Format forum.  I'm just focusing on the pumps because they are a weak point in the printers, and if they are not working, you can't load or clean the machine.  The parking station  must also seal well enough for the pumps to pull the ink through the heads.  You might clean the surfaces that mate when the heads park.
RE: [Digital BW] help with 7500, please
2011-01-02 by Tom Mallonee
Richard,
This is a common problem with the x000 and x500 printers:  The ink is
literally siphoning ink from the capped nozzles into the waste tank. These
printers have two capping stations - one for each head. The reason 3
siphoned and the others didn't is because the conditions for a siphon were
there for one head and not the other. This is much more likely to happen
after a couple of ink charges or repeated cleanings. In theory, this
shouldn't happen - All Epson wide format printers run the suction pump with
the heads un-parked at the end of a  cleaning/flush cycle. The idea is that
the pump should draw any remaining ink out of the waste lines, leaving only
air in them thereby preventing a siphon when the heads are recapped. I think
that once the pads become over-saturated from repeated cleaning or flushes,
the pump doesn't run long enough to always evacuate the waste lines. So if
the waste lines are still full or partially full when the heads recap, the
ink in the tubes running down to the waste tank starts to slowly be pulled
by gravity down into the waste tank. Since there is nothing to break the
vacuum between the waste tank and the nozzles, the ink will keep getting
drawn right through the nozzles and from the carts until you interrupt it or
the carts go empty. The relatively high elevation differential between the
heads/carts and the waste tank on these printers make the siphon all the
more likely and vigorous.
I had two 7000s and the only fool proof way to prevent it was an easy fix:
You can open the front bottom cover, cut each of the two white waste lines,
install tubing tees, and run two 1/8" I.D.  air vent tubes out the back of
the printer and as high up the back of the printer as possible (well above
the carts and heads - or the pump pressure will cause ink to burble out of
the vents).  The tubes can simply be taped or clamped onto the back. By
creating this air-break, it's impossible for a siphon to develop. I took it
one further and abandoned the factory waste tank and just ran both waste
tubes into a covered "Tupperware" container on the floor so I could see the
waste tank level and empty it far more easily. This last part probably isn't
necessary for the average user, but I mix and experiment with inks and do a
huge amount of flushing. On the later printers, Epson has taken several
steps to prevent siphons.
I highly recommend the anti-siphon tubes. I have some documentation
somewhere that I can email you if you're interested. Alternatively, after
repeated cleanings or flushes, unlatch the head and move it to the left a
bit so the heads aren't sealed to the capping assembly. Leaving the heads
uncapped for 5 minutes or so won't hurt anything and will probably allow
enough time for the ink in the waste lines to drain into the tank.
Good luck,
Tom Mallonee
www.ovimaging.com
and on paper?
kilometers).
Richard Vanek
