Carbon 6 printing with QTR ICCs and curves
2011-01-09 by brubaker_family
This is mostly for Paul Roark, but any inputs are welcome:
I am starting to print with the C6 inks on an Epson R280. I recently was able to get a ColorVision 1005 Spectrocolorimeter to use with the SpyderPrint 3 software. I'm a bit confused on how to use the ICC profiles made with the QTR Create ICC RGB. In Paul's C6 Printing Guide it appears that he speaks of both using the ICC in Print Preview and as a printing ICC in PS. In other places I have seen it said that the QTR ICCs are only for use in Print Preview. So, I need clarification on this question.
And if the ICCs are only for use in Print Preview, are QTR created curve file the items to use in printing by applying them to the file before printing?
I note that the SpyderPrint 3 software guide also discusses creating B&W printing profiles with their 225 color target (and optionally adding their additional BW target data). Is this as worthwhile effort to make for the C6 printing process?
Mike Brubaker
Re: Carbon 6 printing with QTR ICCs and curves
2011-01-10 by Paul
ICCs can be used for either or both purposes.
I use the ICCs to give a "color managed" workflow when printing from Photoshop (in a Windows environment) through the Epson driver.  I put "color managed" in quotes because I really don't care about color soft proofing.  I know my print colors.  What I like is that the printer will produce prints that match the calibrated monitor rather well.  So, I work in Gray Gamma 2.2 space and simply hit the "print" button to get to the print preview, pull up the QTR that is for the printer, inkset and paper I'm using, and the print that comes out looks like what I anticipated as I edited the file.
No.
I just use a 21-step test file to print a test strip, read the test strip with the spectro, and dump the results into Create ICC-RGB.  This may be a slight oversimplification, but not much.
Mind you, a lot of work might have gone into making the inkset and finding the Epson driver settings that work best with it.
Also, with some inksets and printers no Epson driver setting works well and Photoshop curves (that are then embedded in the ICC along with the spectro data) are needed to control it. For example, taming the WorkForce 1100, which I'm working on now, has been a challenge.  Its ink limits are terrible.  But, with some basic curves, glossy and matte papers can almost always be printed very nicely.
With the Carbon-6 inkset, hopefully it is close enough when no curve is used that you can just use the Lab L data to "linearize" the output with an ICC.
Good luck with the system.
Re: [Digital BW] Re: Carbon 6 printing with QTR ICCs and curves
2011-01-11 by Brubaker family
Hi Paul,
Thanks for your reply. I have made the ICCs for two papers using the C6 inks in the R280. What I have seen with the ICCs so far is that they do not correct the blocking up of the shadows that occurs on a print with no ICC. On the 21-Step test strip it looks like solid black starting with the 95% step (95% and 100% look the same). The data file from the SpyderPrint3 software looks like the values are pretty evenly spaced:
96.11	-0.21	-2.5392.68	0.19	-1.8689.31	0.45	-0.9786.22	0.62	-0.1383.69	0.74	0.5780.44	1.00	1.3277.48	1.14	1.9073.97	1.27	2.5670.36	1.50	3.0966.27	1.69	3.4762.20	1.73	3.8657.35	1.88	3.9152.44	1.90	3.8947.46	1.88	3.6143.97	1.74	3.6039.43	1.63	3.5933.81	1.65	3.0928.80	1.43	2.3921.09	0.67	0.9417.41	0.18	0.4016.74	0.17	0.27
When I print a test image (Keith Cooper's) and the 21-Step file using the resultant ICC, the results are worse than the test image without the ICC in that the total black appears to start at the 90% step.
Can you make any suggestions to help with this?
Mike Brubaker
--- On Sun, 1/9/11, Paul <roark.paul@...> wrote:
Subject: [Digital BW] Re: Carbon 6 printing with QTR ICCs and curves
Date: Sunday, January 9, 2011, 10:15 PM
No.
2011-01-11 by Paul
Brubaker family <brubaker_family@...> wrote:
> ...I have made the ICCs for two papers using the C6 inks in the R280. What I have seen with the ICCs so far is that they do not correct the blocking up of the shadows that occurs on a print with no ICC.
Correct.  The ink limits need to be set using other methods.  Photoshop curves embedded in the ICC can often do this.  QTR, of course, can also control ink limits -- much better than an Epson driver workflow.
I'm currently working up a WorkForce 1100 "EZ" approach that uses PS curves to control some inappropriate built-in ink limits.  QTR does not support the WF 1100, but the ICCs made with Create ICC-RGB work with any Epson driver workflow.
I've posted a draft of that PDF as well as some of the curves used at http://www.paulroark.com/BW-Info/1100.pdf.  The link to the Zip file with curves is on the first page of the PDF.
I use http://www.paulroark.com/BW-Info/80-100.jpg to determine where the dmax is with the Epson driver.  First, of course, try some  different Epson driver paper types to see what is available in the driver.  The paper type selection is the main way the driver can adjust ink limits.  Keep an eye on both the dmax and the midtone smoothness.  Too much ink there makes for rough prints.
Once you find the dmax point, make a Photoshop curve that goes from 0 to the dmax point.  Try printing with that curve.  If it looks good, you can then use that curve in Create ICC-RGB.  For the curve that goes into the ICC, use the R, G, and B curve, not the overall gray curve.  In fact, I stay in Adobe RGB when setting up a system and ICCs.  In the PS print preview, set "Photoshop controls colors" and set the profile to the Adobe RGB the file is using.  See the screen grabs in the draft PDF noted above.
Hope this helps.
2011-01-11 by Paul
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul" <roark.paul@...> wrote:
> I'm currently working up a WorkForce 1100 "EZ" approach ...
PS: I forgot to mention.  The 1100 workflow I'm setting up is aimed at *all* LK pigment inks.  Dump whatever LK pigments you want into the color carts (with an appropriate K) and print away. I'm trying to make a system that is robust enough to be a generic (and cheap and easy) B&W printer.  Only the pixel peepers on this forum will ever notice that only a single light ink is used.
2011-01-11 by Adventure Seeker
Sent: Tue, January 11, 2011 11:14:33 AM
2011-01-12 by Brubaker family
Thanks Paul,
The link to the 1100 PDF file doesn't work for me.  Can you provide a link that works or email me a copy?
Mike Brubaker
Date: Tuesday, January 11, 2011, 2:05 PM
Hope this helps.
2011-01-12 by Paul
I see the period after the "pdf" got embedded in the URL.  Here's the link sans period:  http://www.paulroark.com/BW-Info/1100.pdf
> I've posted a draft of that PDF as well as some of the curves used at http://www.paulroark.com/BW-Info/1100.pdf .  The link to the Zip file with curves is on the first page of the PDF.
> Hope this helps.
> Paul
> www.PaulRoark.com
2011-01-13 by Mantinieri
Hello Paul,
shouldn't you "convert to " your ICC before printing your GG2.2 file with QTR? As far as I remember, QTR is not color managed and it does not know which is your working space.
Thanks. Ciao,
  Mantinieri
http://www.mantinieri.com
2011-01-14 by Paul
>[Paul wrote:]...
> >So, I work in Gray Gamma 2.2 space and simply hit the "print" button to get to the print preview, pull up the QTR [ICC] that is for the printer, inkset and paper I'm using, and the print that comes out looks like what I anticipated as I edited the file.
Yes, I have convert my files, but with a different procedure.
QTR is not color managed, so a Gray Gamma 2.2 file needs some conversion before printing through QTR.
The seeming inconsistency is probably because I use 2 different printing workflows, both of which use programs in the QTR download.
One of the workflows uses the "Rip" part of the QTR package, for example the 1800 "3-MK" and other "black only" workflows.  I use QTR when I'm printing on Arches because it can take a much higher black ink load than the Epson driver can deliver.
The other workflow uses an ICC made with "Create ICC-RGB" and prints through the Epson driver.  If the inkset is designed to be compatible with the Epson driver, this ICC workflow is, I believe, the easier one to start with.
This was the context of the comment that I often simply print out of Photoshop with one of these ICC-Epson driver workflows.
Most of the inksets I've been associated with are, to some extent, Epson driver compatible.  It's a fast, easy way to print.  The ability to embed Photoshop curves into the ICC gives this workflow significant abilities to control how the inkset prints, but less than one gets with the rip part of QTR.
2011-01-14 by Brubaker family
Hi Paul,
I made a curve file set to 4=0 and added it to the ICC file.  That along with setting the Epson drive to a Contrast setting of -15 gives me a good screen to print match.  From various of your articles I see I could also use another curve file to get the screen match, but the driver Contrast adjustment works fine so I will stick with that for right now.  Now I can get serious about printing!  Thanks for all of your help.
Mike Brubaker
--- On Tue, 1/11/11, Brubaker family <brubaker_family@yahoo.com> wrote:
Subject: Re: [Digital BW] Re: Carbon 6 printing with QTR ICCs and curves
Date: Tuesday, January 11, 2011, 12:56 PM
      Hi Paul,
Mike Brubaker
No.
Colorspan Esprit 54", 11 Color Long Lasting(Endurachrome) Dye Printer
2011-01-15 by jvee
I have a lightly used Colorspan described above which I have not used for at least a year, mainly because no local sales of my very large canvas Giclees that I exclusively printed on this.  Have all the software to include a pure icc workflow.  Does have 4 color gray always on and does a beautiful job,  I just need the floor space.  A fraction of the original cost but must pick up (Central Illinois).  Would make a wonderful teaching fine art printer for educational purposes and would consider donating it for that purpose.  Contact directly if interested.  J Vee  (www.jveegraphics.com)
2011-02-27 by Brubaker family
Hi Paul,
Thanks for your previous help, but I have one more question:
Is it possible to also (in addition to the 0 to 4 curve adjustment I have already done) incorporate an equivalent to an Epson driver -15 Contrast setting into the PS curve?  If this can be done I won't have to make any adjustments in the Epson driver when using the ICC.
Mike Brubaker
No.
