"Scott" <shutterbug1004@...> wrote:
> ...I am curious how others
> feel about the capture side of the process.
> I shoot with a Hasselblad 6cm x 6cm, and scan the negs.
> I print using photoshop and QTR and have
> dedicated 1400 printers for color and b/w work. I use MIS inksets.
> I am curious if anyone is using a digital back for capture at this
> point. (I also use a Canon 5d for digital)
> I'm not sure if its worth it
> to go to the higher priced medium format digital back.
> My test prints seem to be very close at 13 x 19. ...
I used to shoot Rollei SL66, TLR, Bronica RF645 with Tech Pan, and some other MF cameras. I now shoot digital.
I have a Canon 5D2, which convinced me that, for my uses, it was time to transition. Now, for when I want to travel light, hike, and for most things, I use a Leica M9. I think the system is optics limited.
See http://www.luminous-landscape.com/reviews/cameras/2010_mini_medium_format_shoot_out.shtml
In an article called, "2010 Mini Medium Format Shoot-out" a couple MF digital cameras were compared, and just for the fun of it they compared those results to a Leica M9. One quote of interest:
"While the size of the Leica file is smaller than those of the medium format cameras, and therefore display smaller at 100% magnification on screen, we observe that the Leica files have the best sharpness and resolution of all compared here."
At some point as prints get larger the higher pixel count of the MF digital cameras will make them move ahead. At the sizes I print -- up to 22 x 28", printed with a 7800 -- the M9 files are fine.
Just try to find an M9 or any top notch Leica lens in stock anywhere. Most are way back ordered. From what I've seen there are some good reasons. I'm sure there are lots of circumstances when the MF DSLRs are far better, but for the landscape and most other things I do, the M9 is an outstanding capture tool. But, the optics must be really good to take full advantage of that sensor. I also use my 5d2 for somethings, but the M9 has the edge on image quality if the ISO can be low. CMOS is far less noisy at very high ISO.
The 35mm f/2.8 Zeiss (made by Cosina) is my favorite lens, and the only "Zeiss" I've used that can match Leica's top performers.
This is just my opinion based on my limited experiences, which do not include buying and using an MF DSLR.
