thickness of paper for 1400?
2011-02-03 by kg4oqu
I was looking online and epson recommends that the thickest paper that can be run through a 1400 is 11.7 mils or around 200 or 250 gsm. Of the matte papers that most of y'all recommend for b&w printing, which is the papers fall around 200- 250 gsm? Anyone know?
thanks,
Scott
Re: [Digital BW] thickness of paper for 1400?
2011-02-03 by Andrew Darlow
Hi Scott:
Most 300gsm papers will feed fine through the 1400. If you get head strikes, there is a way to let the printer know you are feeding heavy sheets in the driver to increase the platen gap. If you are on Mac, it is under "Extension Settings."
Hope that helps,
All the best,
Andrew
Andrew Darlow
Editor, The Imaging Buffet
http://www.imagingbuffet.com
Author, 301 Inkjet Tips and Techniques:
An Essential Printing Resource for Photographers - http://www.inkjettips.com
and
Pet Photography 101:
Tips for Taking Better Photos of Your Dog or Cat - http://www.PhotoPetTips.com
http://facebook.com/andrewdarlow
> thanks,
> Scott
2011-02-04 by Andrew Sharpe
But not through QTR?
Andrew
On 2/3/2011, "Andrew Darlow" <ad@...> wrote:
>Hi Scott:
>Hope that helps,
>All the best,
>Andrew
>Andrew Darlow
>and
>> thanks,
>> Scott
2011-02-04 by Louis de Stoutz
Maybe I should spell this out again: I use QTR and successfully raised
the head-height on my 1400 through the Epson driver nonetheless.
If you have the Epson driver installed, the printer is in contact
through it with your computer at any time (reporting ink levels etc.).
With QTR you are bypassing the driver only for the print job proper, any
other function remaining intact. So, once you have set the thick paper
setting through the Epson driver, it will stay like that even when you
print through QTR.
(This is just my own deduction, somebody more knowledgeable may want to
correct me if wrong.)
Louis
2011-02-04 by kg4oqu
I am running my epson 1400 on a windows 7 laptop. I checked the user manual, there seems to be an extention settings in MacOS but not in the windows driver. Anyone know how to change the platen size/paper size with the windows driver?
thanks,
scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Louis de Stoutz <loudest@...> wrote:
> print through QTR.
> Louis
Scott, I started a thread 10 days ago on exactly this subject. Look
through the posts of Jan. 27th. Here is the info:
 > For those of you who, like me, didn't know about this feature,
 > you will find it in the
 > Printer Settings -> Maintenance tab -> Printer and Option Information
This is in Windows XP. I imagine that it will be the same in Windows 7.
Louis
> thanks,
> scott
