Shilesh,
> I use the blue ink only to tone the shadow range of print densities, where I like the "purple" look.
I think the OEM PK might be a bit on the greenish side, so I can see where that'd work well.
> The ability to selectively blend 3 curves in QTR is very useful in arriving at the desired print color.
Definitely.
For those who want glossy + matte, the MIS glossy carbons (K4 or MP) plus the colors needed for toning makes a lot of sense.
I moved from the MIS LM to R800 blue in the MIS inksets -- getting rid of the MIS LM entirely. The R800 blue allows one to use less Lc in neutralizing the carbon, thus, perhaps, lessening the green shift. In general, the lower the angle between the toning inks, the less color is needed to achieve the ideal carbon yellow offset (I think -- a few assumptions there). My fade tests were not entirely consistent in showing an advantage to this approach, but I think they provided some weak evidence that the theory is correct.
Epson R800 blue is not available in bulk, but the HP equivalent Z3100 ink is, and that might make a major difference in longevity. At one point I thought of making a toner with the HP inks, but then decided to just stick with the Eboni/Carbon-6 and neutral HP PK (or UT14 or Noritsu) for glossy or more neutrality. If I decide to get serious about glossy fine art, I might still go the route of MIS carbon + HP colors (cyan and blue).
I might add that one of the main reasons I might be interested in "glossy" fine art is the ability to display it without glazing. I used shadow boxes with silver prints before I was selling, and I was pleased to see Marc Muench, in his first museum exhibit, hosted by our local Wildling Museum (see http://www.wildlingmuseum.org/) used a type of shadow boxes for all his color and B&W. That exhibit, for those within range of Los Olivos, California, is an outstanding display.
