Anyone backing up their files online?
Re: [Digital BW] Anyone backing up their files online?
2011-02-10 by Mark Savoia
CrashPlan works great, $5 a month unlimited storage.
Mark
http://www.stillrivereditions.com
On Feb 9, 2011, at 5:00 PM, Lew wrote:
> Rather than to CD/DVD? If so, could you share your experience and observations?
> Lew
Re: Anyone backing up their files online?
2011-02-10 by zz_ir
I'm still not sold on online storage at this point, so I invested $60 in a 1TB Iomega external drive for my primary backup for my files.  It is a great alternative to CD/DVD.  I also have another 160G, secondary external harddrive that I keep off site.
keithz
http://kzarts.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Lew" <lew1716@...> wrote:
> Lew
Re: [Digital BW] Re: Anyone backing up their files online?
2011-02-10 by Dana Myers
I would *highly* recommend using at least a RAID 0 "mirror" for back-up
purposes.  With a single drive, any error results in lost data; the chances
of losing data are substantially less.
Dana
2011-02-10 by Mike Finley
> Dana
NO ... RAID 1
RAID 0 does not mirror, and puts your data at risk from failure of
EITHER drive, as each holds only half your data.
mike finley photography
fine art photography and website construction
http://mypicks.efikim.co.uk
http://www.mikefinley.co.uk
http://www.roguegenecollective.com/Mike_Finley.html
http://www.efikim.co.uk
> > Dana
> NO ... RAID 1
Doh.  Of course I meant *RAID 1* mirror.  It's an off-by-one error :-)
(I knew what I *meant* to say)
Mike is completely correct - RAID 0 "striping" is done to increase
performance at the expense of reduced overall reliability.
RAID 1 substantially improves reliability at little or no cost to
performance (actually, read performance can be substantially
better, write performance slightly worse).
Personally, I strongly recommend running a RAID 1 pair as the
"system drive" in general.
Dana
2011-02-10 by kwalsh74
I am presently using CrashPlan which is very cost effective and efficient.  The initial backup can take a painfully long time due to the size involved if you have a lot of photos, but since it just runs in the background even if it takes a month no big deal.  I presently have 250GB backed up with CrashPlan.  If you have more than one computer, or a friend with a computer you can actually use their software for free to back up to the other machine automatically over the network.
I would *strongly* advise you move away from CD/DVD to at least external hard drives that you disconnect after back-up.  CD/DVD is a horrible media, depending on the disk, the drive, and the software a given burn might last 10 years or less than 10 weeks.  If the drive and software don't burn the disk with the proper exposure pattern the media will fade rather quickly (less than a year) even though an immediate verification of the data just after burning will look fine.  Sadly this is not an uncommon problem and lots of people go back to their CD/DVD archives only to discover there is no longer anything there :(.
Ken
They will rent you a HD for the initial upload, it gets shipped back to them to start.
Mark
This is good; one consideration is that some internet providers have
total usage caps, such as Comcast and 250GB total.  An initial upload
could potentially push one over a threshold like this.
Dana
> Mark
Really, they limit your total bandwidth use per day/week/month/year? That sucks. I have Comcast here and upload and download hundreds of MB every month and they have never said anything. Maybe I just never went over 250GB, that is plenty of data.
Mark
> Dana
Absolutely, Comcast enforces a strict threshold of 250GB total usage per month.
You can find information on this www.comcast.com somewhere.
Yes, 250GB total usage in a month is a *lot*.
2011-02-10 by mrjimbo
Just a tad more info for Raid.. For most folk here I would think that mirroring between two drives side isthe way to go.. It is the slowest preformer both reading and writing.. but it is redundant.. If yo udo it in a hardwar e2 drive set up an dhav ea couple extra trays with drives you can create an off site back up on teh week end and keep it some where else.. As a note it's not the greatest way to go however to select huge drives for a raid set up if you can manage a few more smaller drives to fill the gaps your better off.
Their are many different Raid specks and probably the most popular on a home or small business level is Raid 5 if you nee dmore room and a bit of preformance.  It would use 4 drives that would be striped and with parity.. So you can loose one drive and still retain all your data .. So typically you want a spare on hand.. This is quite reliable and also very fast..Remember that the systems today can read multiple drives at one time so it significantly faster then a mirror set up which just reads one..
jimbo
  Cc: Mike Finley
  Sent: Thursday, February 10, 2011 12:47 PM
  Subject: Re: [Digital BW] Re: Anyone backing up their files online?
  > > Dana
  > NO ... RAID 1
  Dana
Hey Mark,
A lot of places limit bandwidth.. At some point every one will be band width impaired to some degree and or pay for what your using..  All the satellite companies have already done it..  Starband cut your band width at 500MB so you can't even down load a movie..
j
  Sent: Thursday, February 10, 2011 1:13 PM
  Mark
  > Dana
RE: [Digital BW] Re: Anyone backing up their files online?
2011-02-10 by Paul Grant
For what it is worth I prefer the Raid 10.   It provides less capacity than
the Raid 5 but the Write performance is so much faster.    I use the Raid 10
as my main library and then incremental backups to other SATA drives.    I
also copy data to other drives for off site backup.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of mrjimbo
Sent: Thursday, February 10, 2011 1:03 PM
your better off.
jimbo
Cc: Mike Finley
chances
> > Dana
> NO ... RAID 1
Dana
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 5863 (20110210) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
http://www.eset.com
Mirroring (RAID 1) well implemented has read performance similar to RAID
0 (alternate sectors read from each drive). Poorly implemented it will
have the same read performance as a single drive (data read from only
one drive, the other being ignored). I would hope that by now the former
would be more common.
It is probably slowest for writing.
It is probably fastest for rebuilding. (RAID 0 can't rebuild, RAID 5 has
to read every remaining disc for each sector and calculate what should
be written to the replacement disc. If you know you need one of the
other RAID configurations, you don't need advice from me!)
2011-02-10 by Michael
When making your initial online backup, you can greatly reduce the time required if you adjust your computer's power settings so it does not go into "Slumber" mode until the 1st backup is completed. Also, you can sync between computers very easily using Microsoft's Live Mesh service which allows individual files or folders to be synced between boxes and/or to a small free storage on their cloud. This is good for syncing My Documents, music, etc. between boxes.
2011-02-10 by lgrrrb@bellsouth.net
My safest backups are clean negatives stored in the bank safety deposit box. Next, a 1TB external hard drive stored in the bank. Then, another 1TB external hard drive at home which I update and swap with the other drive in the bank.
Another question to ask is WHAT digital files do you backup? I backup (a) all original files after only spotting and cropping, (b) all edited and flattened files, and (c) edited files with layers in the case of important (or difficult) images.
Randy Bresee
www.RandallRBreseePhoto.com
> Lew
2011-02-11 by mrjimbo
Raid 10 works quite well .. a good option..
j
  Sent: Thursday, February 10, 2011 2:21 PM
  Subject: RE: [Digital BW] Re: Anyone backing up their files online?
  _____
  your better off.
  jimbo
  Cc: Mike Finley
  chances
  > > Dana
  > NO ... RAID 1
  Dana
  http://www.eset.com
  http://www.eset.com
2011-02-12 by Paul
"lgrrrb@..." wrote:
> My safest backups are clean negatives stored in the bank safety deposit box. ...
That's the direction I'm leaning also -- letter size film images that can be sleeved and put into a standard bank box.
Carbon on cotton may be the most "archival," but the signal to noise ratio is not very good.  Viewing and extracting the best image involve different criteria.  I might be willing to give up some longevity if the image quality trade off is high enough.
I'm now looking at the smoothest substrate and glossy carbon inksets.  I think the digital internegative group may have a lot to contribute here.  In my experience, Pictarico films may be the sharpest.
I'd like to learn more about the relative longevity of a film base. It has to be coated, but I'd think if they really do use a quality film base, there would be less internal stresses than the RC approach.
2011-02-12 by Barrett Benton
Dana Myers writ:
> chances
You've probably been raked over the coals enough times before I got
to read this, but I'll reiterate: RAID 0 is a Really Bad Idea if one
is relying heavily on that data on those two (or more) lashed-
together drives. I recently had to come to the rescue of a client
whose Dell tower crashed and burned in the middle of a project;
pulling off the cover I found two HDs. He said he *thought* one drive
was a backup, but after ten futile minutes attempting to boot, I go
into diagnostic mode and see the dreaded words: RAID 0, followed by a
fatal-error alert for the second HD.  "Absolut Toast", with a touch
of bitters.
RAID 0 was probably cool when drive capacity was relatively small and
pricey: with 1, 2, and 3TB disks "on the hoof" these days, it doesn't
make much sense to me. RAID 1 makes more sense, but again, other than
for backup capacity (I'll likely be switching the drives in my LaCie
network drive from a pair of 500GB drives to a pair of 2 or 3TB
drives), I don't quite see the need. (Your mileage, etc.)
- Barrett
2011-02-12 by Dana Myers
On 2/11/2011 8:06 PM, Barrett Benton wrote:
> Dana Myers writ:
> > chances
It's a crapping thinko.  Ignore the word "RAID 0" and note the
word "mirror" and the description of a RAID 1/mirror.
Mirror is what I meant, and RAID 1 is correct.  It's just an off-by-one
error.  I actually understand this stuff :-)
Dana
The need for RAID 1? It's to insulate the user against
single-drive-failure catastrophes.
Dana
2011-02-12 by mrjimbo
Paul,
Your thoughts on this are practicle and make sense. Film still is one of if not the best acrhive materials when properly executed. B&W film is tooted at 500 years in dark storage when temperature and humidty control are in place...and that's not frozen.. Realistically today most of us are all using data so in addition to the film a system of archiving data needs to be going in parallel.. And for those that  are shooting digital their really is no other recourse unless they get a folm recorder which in that cas emay not make the best sense...The information possible on a paper print will never come close to that in a raw digital file nor  anegative simply due to the varience in dynamic Range that's possible.
Digital negatives are another option ..I've been fooling with these to make contact prints and am really enjoying the process .. These negs however are fairly fragile and can easily be damaged ..
The world has and is changing we still have lots of options .. I think it boils down to how well we execute our options for our personal needs..
jimbo
  Sent: Friday, February 11, 2011 7:14 PM
  Subject: [Digital BW] Re: Anyone backing up their files online?
2011-02-12 by kwalsh74
Just to add a little more to the discussion, remember a key point:
RAID is not a backup!!!!
RAID protects against just one thing, hard drive failure.  That is it.  That is not necessarily even the most likely failure, just one of the common ones.  Your OS could thrash your entire array.  Your RAID controller could thrash your entire array (actually saw this happen to someone).  You could accidentally delete/overwrite/format your own data (did this to myself once, fortunately the data loss was not very large and could be recreated with work).  A virus could corrupt all your data (saw someone do this to their work group's network mounted drive, lots of unhappy campers).  And so on.
Now, RAID is probably better than not backing up at all.  And similarly if it is something that happens automatically whereas another backup option is one you must manually do and frequently don't then it has benefit.  But it really isn't intended as, nor does it function particularly well as a backup.  It only protects you from hard drive failure, and that is only one threat to the data.
And it is certainly worth consulting this site to get one's mind in the right place about backing up:
http://www.taobackup.com/
Ken
Ken,
I think your off on the wrong foot with this.. I certainly agree that the word Raid does not equal back up.. But  Raid setups or systems as part of a back up plan certainly functions as just that,  a part of a back up plan.. In truth CD's and DVD's, Tape Drives , flash drives ..you name it they can all be part of a back up plan..
In my environment I have simply made a choice to use primarily hard drives as my vehicle of back up for data.. In truth we have a fairly good back up plan over all I think.. Using Raid driven redundancy is part of that plan.. We do not operate our computers off it .. It is merely a storage and back up plan which we find to have proven advantages over other ways of doing it..
It appears that your post doesn't address the possibility of using Raid as part of a back up plan... You are correct in that all it primarily does is protect against hard drive failure but it also really speeds thing up also if your set up to do so. So in truth ..a raid set up can be used as part of or not part of a back up plan.. Are you suggesting that it can't be that way?
jimbo
  Sent: Saturday, February 12, 2011 10:11 AM
  Ken
2011-02-12 by pdesmidt tds.net
I'm not a fan of using Raid arrays as part of a back up.  Raid controllers
can fail.  I know this, as I've had it happen.  I do have more than one
drive in my machine.  One is only used as a backup of the main photo storage
disk using Cobian back up.    Thus, I have two copies of my data in my
computer, and if one disk was to fail, I'd be ok.  As far as back up goes,
that seems to accomplish what a mirrored raid does without adding another
point of possible hardware failure.  I combine this with multiple back ups
on external hard drives.
2011-02-12 by Paul
"mrjimbo" wrote:
> ... Film still is one of if not the best acrhive materials ...
And it is a coated substrate.
>...The information possible on a paper print will never come close to that in a raw digital file nor  a ...
Particularly if the image size is limited to letter size, which is not irrational given the difficulty of storing larger prints.
> Digital negatives are another option ..I've been fooling with these to make contact prints and am really enjoying the process ...
In my transition from the wet darkroom I first used a variety of digital negatives.  The high end commercial ones can be impressive, but also impressively expensive -- really not an option for me.
I was depressed at the quality of the inkjet negatives I tried because my goal was to be able to enlarge an 8x10 negative to 16x20 inches, which was my standard display print size.  Inkjet negatives of the day just could not be enlarged.
What I found that was the poor man's film recorder that allowed 2x enlargement of an 8x10 negative was the Fujix digital printer.  Samy's in nearby Santa Barbara had one.  It made 400 true RGB pixel per inch images that could be on overhead transparency substrate -- for $8!  So, for a few bucks I had an 8x10 B&W negative that would enlarge to 16x20 and look very good.
I'm going to see how close I can come to that with a 1.5 pl inkjet and a full 6-dilution glossy carbon ink.  A 720 dpi file can contain 14.4 lp/mm resolution.  All we need in a final 16x20 for it to look sharp is 3 - 5 lp/mm.  So, the 720 dpi 8x10 file is fine.
When I look at a paper print of a 720 dpi resolution test strip I can see with a scanner those 14.4 lp/mm lines, but they are very ragged and barely visible.  It's close, but what I'm seeing on paper just won't cut it for enlargement.  So, onward to the glossy substrates.  I've ordered some of the Pictorico white gloss film.  I'll do an initial test Ilford's best today.
>... I think it boils down to how well we execute our options for our personal needs..
Since inkjet is my preferred output now, I'm aiming at the best way to use this technology, with very affordable inputs, to accomplish the goal.
Of course not.  My recommendation was that the *back-up* storage
should be in a redundant RAID 1 "mirror" configuration.  (Yes, I know
I wrote RAID 0 in my original message.  That was an error).
I'll repeat this again: backups to spinning storage should be
to at least a RAID 1 mirrored pair.  This greatly reduces the chance
that your backup storage will fail when you actually need it.
I also recommend that the "system" storage should be a RAID 1
pair.
Have you read this?
http://labs.google.com/papers/disk_failures.pdf
Dana
2011-02-12 by mrgs1001
It is most unfortunate but the bottom line is that hard drives have a 100% mortality rate. It is not a question of will it fail; it is only a question of when. Although a hard drive will fail, it will retain the magnetically encoded data indefinitely although this can be very costly to remove from a failed hard drive. CD/DVDs will not hold data indefinitely. CD/DVDs lose data overtime due to oxidation. Depending on the media, burn process, and storage of the media the life expectancy has a huge range of 2-20 years.
On my servers, I use redundant mirrored RAID hard drives. Unfortunately, RAID is of little use if the server is destroyed or stolen so I also use offsite backup. For automated daily backup I use on online service. I also like to have months old copies of the data and every now and then you run into problems with backup services or software failing. For that reason, I also have a networked Terabyte drive that I plug monthly into the network and do a full backup and then take that drive home. That gives me two offsite backups created in different ways so if my entire business burns down I have good odds of recovering most of my data.
Mark
http://www.facebook.com/FrameDestination
