[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Rusty
Sterling
Sent: 03 March 2011 07:02
Subject: [Digital BW] Re: QTR Profiles for R200 and MIS
Yow! I hardly understood anything you said. I have read everything you wrote
and Clayton Jones wrote.
Now you latest missive indicates how outdated things might be.
I just got my new MIS inksets today. Given what I just read I'm still not
sure how to use them with QTR for the R200. I'll continue to use my R2880
with ABW, so that is not a problem. But I really want to use these inksets
with the R200 effectively.
I'll read what you said and ponder it. I hope it ultimately helps. We shall
see.
Rusty
--- In DigitalBlackandWhiteThePrint@yahoogroups.com
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Paul"
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Rusty Sterling"
<rustysterling@> wrote:
> > > I've been looking for profiles for the R200 ...
> "Roy" <roy@> wrote:
> > You ought to start with the workflow of the one who designed
> > the inkset. See Paul Roark's write up about UT-R2.
> > (note that the R220 and R200 are essentially identical)
> > http://www.paulroark.com/BW-Info/R220_R2_Readme.pdf
> And note the date on that PDF.
> Newer versions of Photoshop and possible even OSs may have trouble with
the use of ICCs and the printer driver's "Color Controls."
> The systems now are emphasizing ICCs with the printer set to ICM/No Color
Adjustment. This is probably an effort to avoid people using 2 profiles
together accidentally.
> I think I agree with the emphasis, but it does make the use of the old
workflows problematic.
> I think moving forward ICCs with standardized Epson driver settings may be
the easiest way to support the older or smaller market printers. If
variables are cut to a minimum, a few generic ICCs will be easy to make and
support whole families of printers and inks.
> I'll make a limited number of these for a few papers & printers. The 2880
with a monotone is going to be a platform like this, for example.
> The MIS R2 inkset is one that was made for the Epson driver. That is, it
uses densities that usually fit well into the Epson cross-overs and produce
a good ramp with the built in default profiles. These are what I've called
the UT-C and UT-LC densities. Ut-C is the standardized 30% jump down from
MK. (LK is the 30% dilution down from PK.) Dropped into an Epson hextone or
better printer, the R2's UT-C and LC densities look good. Add an ICC to make
it better. This type of inkset is the easiest to support. That's why it was
called the hextone EZ set.
> Paul
> www.PaulRoark.com
