Sent: Thu, May 5, 2011 8:30:09 AM
Subject: [Digital BW] Re: Solarization
Dan, <hackberrytree@...> wrote:
> Hello, I have searched for the topic on what appears to be solarized tones
>and need some help. I am just started using an epson 1400 with the eboni 6 set.
>If I go to the epson 1400 driver on just grayscale, the prints come out fine.
That is a good sign. In my PDF on Eboni-6, I recommend people start with the
Epson driver. See http://www.paulroark.com/BW-Info/Eboni-6.pdf
In fact, I'm not sure there are any Eboni-6 QTR profiles in my profiles Zip
file. I assumed, perhaps incorrectly, that those who use the rip knew how to
make their own profiles.
The Epson driver with ICCs made with QTR's "Create ICC-RGB" makes an excellent
workflow for Eboni-6 in the 1400.
> As soon as I use the Quad tone with the entrada natural curves the image goes
>to pieces.
I suspect you're using a profile that was not intended for Eboni-6. Be sure
the profile name says "Eb6" or "Eboni-6" in the name of the profile.
Again, start with the Epson driver workflows, including the ICCs that have Eb6
in the names.
Hope this helps.
