QTR Calibration Mode
2011-07-01 by Mel
I posted this question on the QTR forum, but have not yet had any replies - perhaps I will get some advice here. I am about to start using a choice of paper curves not included in QTR for the Epson 1290. I can follow Tom Moore's workflow when he shows an example using an Epson 2200 with the Epson supplied Ultratone inks, as that printer only uses black and light black for monochrome prints. My setup uses an Epson 1290 with UT2 inks. In Tom Moore's User Guide he says:- "For Quadtone inks, this process is repeated for each lighter ink, comparing it to the next darker ink......." The problem with the UT2 inks, is which are the lighter and darker inks, as they are not all descending tones of grey - the Magenta and Light Magenta positions are a Sepia colour, Cyan and Light Cyan are a greyish blue and the Yellow position is a light brown ? Is the dark to light as they are printed out on the Calibration Ink Pattern, i.e. Black, Cyan, Magenta, Yellow, Light Cyan, Light Magenta. As I have not yet obtained a densitometer do I need a colour one or can I take density measurements of these different "colours" with a black & white densitometer. To quote Tom further:- "Hardware Ink Limit .....This can be done visually by just seeing the test print and deciding where the inks seem to max out -- i.e. fill the patch" I realise this is where there are no white specks in the patch, so is this where you can't see a difference beween patches ? I think I need an example of the method of obtaining curves for the 1290 with UT2 inks. Perhaps someone out there has done it. Mel
