equivalent to K4 PK
equivalent to K4 PK
2011-08-07 by benoit.lantoine
Hello
I would like to know if K4 PK is the same as UT14 C
Am I wrong ?
14$/4oz for the first one, and 18$/4oz for the second one ....
Thanks.
Re: equivalent to K4 PK
2011-08-08 by Paul
Ut14 M is k4-pk.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "benoit.lantoine" <benoit.lantoine@...> wrote:
> Hello
> Am I wrong ?
> Thanks.
2011-08-08 by benoit.lantoine
Hello
Can't figure out why because in eboni4+inkset , ut14c is used as PK ink
Thank you
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul" <roark.paul@...> wrote:
> Ut14 M is k4-pk.
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "benoit.lantoine" <benoit.lantoine@> wrote:
> > Hello
> > Am I wrong ?
> > Thanks.
2011-08-08 by Paul
> ... in eboni4+inkset , ut14c is used as PK ink
For the UT14 inkset, be sure to read
http://www.paulroark.com/BW-Info/UT14.pdf
UT14-C is a neutralized PK.  Neutralized PK's (PK plus cyan and some R800 blue) are darker than straight PK.  You can use either UT14 M or C to generate the 100% black on glossy papers. I think you'll see the profiles in the Zip file (the PS curves that are embedded in the ICCs for glossy paper) use both C and M.
In the Eb4+ inkset the only glossy compatible PK is the PKn from the UT14 inkset (or other neutralized PKn, depending on which glossy option is used).
I hope this helps.
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul" <roark.paul@> wrote:
> > Ut14 M is k4-pk.
> > > Hello
> > > Am I wrong ?
> > > Thanks.
