Which Inkset is this
2011-09-20 by Greg
Back in May I received an inkset from MIS. The order was for a UTFSN inkset to suit an Epson 2000P.
According to the data published on the site, there are only 4 inks in this set, fitted to the printer as C M C M Y.
But this set does have 6 different grays. As a quick test I used a cotton bud to put 6 swabs on some paper. Scanned and measured in Photoshop, the L values are:
UTFSN-K   28
  "   C   40
  "   M   38
  "   Y   70
  "   LC  52
  "   LM  63
The photo black bottle is labelled UT-HEX-4-PK
Is this a UT-HEX, Eboni-6, UT2 or other inkset?
Cheers
Greg
Re: Which Inkset is this
2011-09-20 by Paul
I'm not sure what it is.  The C and M measures are close enough to be the same.  Swabbing is not all that accurate.  The Lm andLc look too far apart, however.
Are the tones of all but the K the same?
Www.paulroark.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg" <gregnixon@...> wrote:
> UTFSN-K   28
>   "   C   40
>   "   M   38
>   "   Y   70
>   "   LC  52
>   "   LM  63
> Cheers
> Greg
2011-09-20 by Greg
Hi Paul,
No, the swabs are not all that good, but I did measure from the most dense sections of the swabs.
Its difficult for my unpractised eye to tell, but C & M look the same as each other, LC & LM are the same as each other, but slightly more blue than C & M.
You can see the RGB scan here
http://www.flickr.com/photos/35706661@N08/6166077071/in/photostream
I will have to load some carts and print a calibration scan.
Do you have to flush the Claria inks from a 1400 before fitting the UTFS carts? Will an initial fill sequence be enough to flush out the Claria inks?
Cheers
Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul" <roark.paul@...> wrote:
> Paul
> Www.paulroark.com
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg" <gregnixon@> wrote:
> > UTFSN-K   28
> >   "   C   40
> >   "   M   38
> >   "   Y   70
> >   "   LC  52
> >   "   LM  63
> > Cheers
> > Greg
2011-09-23 by Paul
That could be the right inkset.  I'd go ahead and load the carts.
I doubt it.  I've had Claria & Noritsu (same dyes) inks in the 1400 with MIS inks for some time. (The old time, e.g., 1280, dyes and HP dyes are a totally different matter.  They are very incompatible with MIS inks.)
No.  Do a couple cleanings and print Purge6 pages to be sure the colors are out of there.  It takes very little high gamut color to affect the new inkset hues.
2011-09-23 by Greg
Hi Paul
Thanks for the reply. The C and M are the same ink. The LC and LM should be the same, but are slightly different. This could just be a change from batch to batch.
I have loaded the carts, flushed out the heads using the direct flush method, 2cc of Windex each. A couple of cleaning cycles and its looking ok.
I have scanned the separations at 70% limit here.
http://www.flickr.com/photos/35706661@N08/6173979213/in/photostream/
Looking down at the 100% end of the separations, the inks seems to change away from neutral grey. It that how it is supposed to be?
The 21step linearised grey here
http://www.flickr.com/photos/35706661@N08/6173979471/in/photostream/
You can see the change in grey tone around 45/50/50%. The lighter Y takes over from there down. There are some odd colour shifts at the lighter ends which are not there on the original. I must re-profile the scanner.
I have an IT8 target with the 24 step greyscale at the bottom. Is that a linear scale? can I use that greyscale to make an icc?
Cheers
Greg Nixon
> Paul
> www.PaulRoark.com
Epson Printers Purge cycles
2011-11-21 by Globe Trotteur
I have now an epson 2200 with refillable cartridges. I usually use it on week-ends but it looks like every time i turn it on, it goes through a clean cycle. I do not know if it is due to a cartridge chip being reset. When i used to havea R220 with a CIS, i do not recall having this behavior.So i do not know if only one cartridge is being cleaned or all of them.Is that a normal behavior? Thanks.Pierre
