compromise needed
compromise needed
2011-09-25 by benoit.lantoine
Hello,
I've already tried the following on my epson 1400 :
BO using MK Eboni on various non OBA papers
EB6 on Epson Hot Press Natural
I would like to get cooler prints. I don't know which setup is the best compromise between durability and neutrality :
- EB6 on BW papers (Epson Hot Press BW is OK ? Has anyone tried the new Harman by Hanhemuhle Cotton Smooth papers ?)
- Eboni based inkset containing dyes to get cooler prints (EB4+, UT14, EB1400) on non OBA paper
Thank you all.
Re: compromise needed
2011-09-26 by fotofantom
I am surprised to see that UT-14 contains dyes.  Is this true?  I thought it was all pigment.
Greg F.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "benoit.lantoine" <benoit.lantoine@...> wrote:
> Hello,
> Thank you all.
Re: [Digital BW] compromise needed
2011-09-26 by Ernst Dinkla
I guess an inkset mixed from the HP PK Vivera pigment ink and an OBA
containing paper that keeps its white according to Aardenburg tests
would be the best in durability and should be cool to neutral. Anything
beyond will need a blue pigment ink addition.
Met vriendelijke groeten,   Ernst
Try: http://tech.groups.yahoo.com/group/Wide_Inkjet_Printers/
|      Dinkla Grafische Techniek      |
|         www.pigment-print.com        |
|                 ( unvollendet )                 |
2011-09-26 by Paul
That issue was the purpose of my experimenting with the various cooler inks in the "Eboni-4 Plus" write-up.
See http://www.paulroark.com/BW-Info/Eboni-4-Plus.pdf
The easiest and cheapest of these to implement is to use the MIS UT14 C and LC.  The most lightfast would be to use the HP Z3100 PK and Gray (LK) (OEM or user mixed).
UT14 does not use dyes.  The coolness is from MIS color pigments.  For all by museum work, the UT14 is stable enough.
The only dye inks I use and recommend are the Epson-Noritsu (Claria) dyes.  Some http://www.aardenburg-imaging.com/ fade testing suggests that these dyes might actually be more stable than at least some third party color pigments.  I take no position on this.  Mixing the dyes to get a lighter gray ink may be more than you want to take on now.  Using just the K dye may result in a print that is too green.  So, my initial reaction would be to avoid the dyes at this point.
The OBAs in papers are dyes and are known to "fade," causing the paper tone to drift to that of the natural, underlying paper.  How bad is this?  It may depend, in part, on how warm the underlying paper is.  In terms of the total image tone stability, it's not good, but, frankly, I look at where the final image tone will be and what the tonal drift path is.  We're not talking about a drift into the green zone.  There is no image fade, and the final image -- possible years from now -- may be no different than if you'd used non-OBA paper to start with.  My main concern with using brightened paper for images that are sold is that years from now if the print is taken out of the matte, there will be a difference between the image tone where the matte covered the paper and where it didn't.  (If/when I can put about 1% yellow on the border to control that and not over-mat image, I may have almost no concerns with using good brightened paper.)
I'd recommend, bottom line, that you try the Eb4+ approach with UT14 cool C and LC.  It's easy and cheap to buy a couple carts to test and then bulk ink if you like it.
2011-09-26 by Paul
UT14 does not contain dyes.  It uses MIS color pigments to cool the warm MIS glossy carbon in the C and LC inks.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "fotofantom" <gfight@...> wrote:
> Greg F.
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "benoit.lantoine" <benoit.lantoine@> wrote:
> > Hello,
> > Thank you all.
That's good to know.  Thanks Paul.
Greg F.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul" <roark.paul@...> wrote:
> Paul
> www.PaulRoark.com
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "fotofantom" <gfight@> wrote:
> > Greg F.
> > > Hello,
> > > Thank you all.
2011-09-29 by benoit.lantoine
Hello Paul
Thank you for the explanations.
One more question: what about eb1400 since only one carbon ink mixed with color is needed? Wouldn't it make the prints more stable than prints made with eb4+?
Have a nice day
> Paul
> www.PaulRoark.com
2011-09-29 by Paul
http://www.paulroark.com/BW-Info/Eb1400.pdf
I think they would have the same lightfastness.  In Eb1400 a single HP Z3100 PKn or UT14C (also a PKn, slightly cooler than the HP) is used.  In the Eb4+ mix the lighter (more dilute, LK) versions of these neutralized PKn's are put in the LC position.  For any given print tone I think the same amount of color pigments would be used.  So the reduction in longevity relative to 100% carbon would be essentially the same.
The Eb4+ -- http://www.paulroark.com/BW-Info/Eboni-4-Plus.pdf -- is going to be smoother and easier to profile where you want cooler prints.
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul" <roark.paul@> wrote:
