Failed Epson 1400
Failed Epson 1400
2011-12-10 by R Craig Blackman
Paul, et al;
I use the Epson1400 with MIS inkUT14.
Installed six new cartridges two days ago.
The package stayed in my mail box overnight and it was near freezing.
After reading the instructions, I installed the cartridges WITHOUT waiting for three hours to allow the ink to warm up.
Tried to print...surprise, nothing on the paper. Feed worked perfectly.
I ran all the cleaning and aligning tools, but still not printing.
This am, I tried to print again, and there was evidence of ink printing.
I tried the cleaning again and ran the Nozzle check. There was nothing on the paper.
I would welcome any suggestions that will put me back in the print business.
Thank you,
Craig
Re: Failed Epson 1400
2011-12-11 by Paul
Assuming you took the air inlet tabs off, I'd guess some air got into the outlets, perhaps because the ink was too viscous to flow right.  So, you might want to use a bottom fill adapter and syringe to prime the carts.  Take the reservoir fill plug out and pull some ink through the outlet.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, R Craig Blackman <blac1588@...> wrote:
> Paul, et al;
> Thank you,
> Craig
2011-12-11 by R Craig Blackman
Paul, I followed your advice and removed the plugs; three were still in the cart.
I am printing again.
Thank you for all that you do for this group.
Craig
To: "DigitalBlackandWhiteThePrint@yahoogroups.com" <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Saturday, December 10, 2011 12:38 PM
Subject: Failed Epson 1400
Paul, et al;
Thank you,
Craig
