Seth
We're talking about different things here. I am not talking about how to convert an image to B&W. There are a multitude of ways to do that, some of which you note below. (I still use the split channels method - all of R, G, B, L* from Lab, C, M, Y, K.)
I am talking about how you manage the gamut compression from file to print.
As for the hue selection in ABW, that I believe is a personal preference. (I like warm tone prints and my favourite is 10-20.)
Re the use of colour ink by ABW, here's a clip from a post Roy made in 2007:
"Since there's been talk about the two Epson driver modes I thought
it would be worthwhile seeing how they compare in ink usage.
The following "prints" were done to a file and analyzed to see what
commands were being sent to the printer.
Comparison of ink usage from the Epson R2400 with Epson driver
Image - grayscale 21 step wedge
Paper - Velvet Fine Art
Quality - Best Photo (1440x1440)
Both prints use 2 dot sizes, percents are weighted based on drop size
Epson ABW driver - neutral
total 100% dots 9,763,341 small 2,532,646 medium
K 31.27%
LK 26.15%
LLK 21.03%
LM 12.76%
LC 7.92%
Y 0.87%
Epson standard driver - Epson Velvet Fine Art profile
total 100% dots 10,393,768 small 2,694,351 medium
K 32.84%
LK 49.40%
LLK 1.29%
M 3.25%
LM 4.39%
C 2.90%
LC 2.37%
Y 3.54%
Some observations:
ABW uses a lot more LLK --- 16 times!
ABW uses a lot less Y --- 1/4 the amount
ABW uses no dark C and M
Interestingly this really supports the idea of replacing the Y
ink with a LLK ink with either driver.
Roy"
On 2 Mar 2012, at 14:19, Seth Rossman wrote:
> I just want to throw something in that you may want to test along with
> what you are doing already. I ran into this while doing a test book.
> In their case they had a "convrt to B&W option--less than perfect.
> What I do--even with ABW, etc.--is open a copy of a file and do a
> convert myself. This helps in a couple of ways. First of all, a
> generic PS convert to B&W assumes a lot by the software. Other folks
> simply do a full desaturate but leave it in RGB--also not great IMHO.
> I use Adjustments> Black and White. Couple of options here. First I go
> through the old school (I am) and see what the green, orange or yellow
> filters do in the options box. I usually wind up adjusting the color
> filters further, controlling sky, vegetation, etc. where I get both the
> detail and densities I prefer in each are. Think Zone System; think
> WWAAD--what would Ansel Adams do?
> After that, the RGB information is still there. NOW I convert to B&W
> using >Mode. I know it seems redundant, but it removes the possibility
> of any tints being left behind. (Some others' books where printing B&W
> with slight green or magenta tints. Mine had none perceptible, though
> the iOne Pro can always find something.
> Now when I throw this to ABW, or whatever, I am dealing with pure Ks.
> I know ABW is throwing some color pigment in there though. With yellow
> being the weak link, I normally drag "southwest" about -11 to -19 to
> force the ink to the more stable Cyan side. It doesn't seem to affect
> the B&W print appearance.
> Just a thought.
> Seth
