Printing profile targets
2012-04-08 by sethrus
Has anyone tried using QImage (the original) to print profile targets with sizing, ppi, etc. turned off?  Does it work accurately?
I am concerned with reports that the Adobe ACPU is resizing targets.  And, the fact that it prints to one corner and edge of the page.
Seth
Re: [Digital BW] Printing profile targets
2012-04-09 by Steve Kale
It didn't do this when I used it
2012-04-10 by Ernst Dinkla
> Thanks,
> Seth
Qimage does that job perfectly with CM switched off and the driver's
setting to "Let application control CM".
There was a target resolution like 40 pixels per cm at print size that
did not alter the scaling in ACPU. Someone figured that out.
Met vriendelijke groet, Ernst
Dinkla Grafische Techniek
Quad, pi\ufffdzografie, gicl\ufffde
www.pigment-print.com
2012-04-10 by Seth Rossman
Thank you Ernst-
The I did that last night.  The problem with ACPU is positioning.  It
wants to creep to a corner instead of centering the target.
Also, for some reason. the PS Elements 10 still has "No Color
Management" as an option.  I printed from all three last night and will
read them today to be sure there is no variance.
The PSE 10 thing is strange!!  Adobe says they took the NCM out of PS
because it "confused some users."  Anyone confused by that should not be
using PS, in my opinion.  Then they LEAVE it in PSE--the amateur
program.  Who is doing the thinking at Adobe?
Seth
Apple does that for them these days.
2012-04-10 by Peter Marshall
So that explains why PS is so expensive!
London's May Queens: http://bit.ly/zQ7k7n
In Search of Atget: Paris 1984 http://is.gd/oRLosu
Still Occupied: A View of Hull 1977-85 http://is.gd/GwtO3o
Before the Olympics: The Lea Valley 1981-2010 http://is.gd/dp02K
Peter Marshall    -    Photographer, Writer: NUJ
petermarshall@...
2012-04-10 by Tony Sleep
I did some years ago, and Qimage was fine.
Tony Sleep
http://tonysleep.co.uk
