Epson K3 Photo Black and LK
2012-04-27 by Paul
FWIW, the 7800 LK appears easy to make by diluting the Epson 7800 PK with the generic base at a 1:1 mix ratio. I was surprised that the PK to LK step was 1:1 as opposed to closer to 30% PK. I did not make an LLK dilution, which, again, is typically 30-33% LK, remainder clear base. The Epson 7800 PK and LK are more neutral than the MIS glossy carbon, but the Epson "gray" inks also appear to be blends that are more than just carbon pigments. The Epson MSDS for the ink says the PK has less than 3% carbon black and less than 5% "proprietary dyes and pigments." It would not nice if it were carbon only, but it appears not to be the case. Wilhelm makes reference to the "carbon based" black inks, but it appears carbon may not even be the primary pigment. Paul www.PaulRoark.com
