Looking for a neutral matte paper with Eboni
2012-07-10 by Sylvain M.
Hello all,
I'm looking for a matte paper (such as HPR, for
example), OBA-free, that would give the most neutral tone as possible
(or even a little bit cool) with Eboni inksets. Of course the best Dmax
is also welcome :o)
Could anynone give me an advice?
Thanks in
advance!
Sylvain
Re: [Digital BW] Looking for a neutral matte paper with Eboni
2012-07-10 by Ernst Dinkla
On 07/10/2012 08:20 AM, Sylvain M. wrote:
> Hello all,
> is also welcome :o)
> Thanks in
> advance!
> Sylvain
With Lab a and b values close to zero you will have a paper that is
neutral. With a negative b value it will be cooler.
If you keep the cursor on the paper name in SpectrumViz the Lab values
of the paper white are shown. For example Somerset Museum Rag 300 gsm,
100% cotton, Lab 97.0 0.4 0.3
340+ paper white spectral plots:
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
Met vriendelijke groet, Ernst
Dinkla Grafische Techniek
Quad, pi\ufffdzografie, gicl\ufffde
Thx Ernst.
However, you give the Lab values for the paper itself
only. What I'm looking for is a paper giving neutral tones with EBONI
inks, in the high lights as well as in the shadows.
Sylvain.
On Tue, 10 Jul 2012 09:41:24 +0200, Ernst Dinkla wrote:
> On
>> Hello all, I'm looking for a
matte paper (such as HPR, for example), OBA-free, that would give the
most neutral tone as possible (or even a little bit cool) with Eboni
inksets. Of course the best Dmax is also welcome :o) Could anynone give
me an advice? Thanks in advance! Sylvain
to zero you will have a paper that is neutral. With a negative b value
it will be cooler. If you keep the cursor on the paper name in
SpectrumViz the Lab values of the paper white are shown. For example
Somerset Museum Rag 300 gsm, 100% cotton, Lab 97.0 0.4 0.3 340+ paper
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm [1] -- Met
vriendelijke groet, Ernst Dinkla Grafische Techniek Quad, piëzografie,
giclée www.pigment-print.com [2]
Links:
[1]
[2]
On 07/10/2012 11:38 AM, Sylvain M. wrote:
> Thx Ernst.
> Regards
> Sylvain.
Paul Roark's Eboni-1400 PDF gives a good impression of what Eboni
diluted and Eboni Black Only does with various papers. The Eboni is not
neutral itself to start with and it will be hard to get a full range
neutral without color toning that ink.
Yes, this is something I'm aware of... I use the UT14-C ink from
MIS in the inkset to compensate. But I would like to go to pure carbon.
I'm currently using Hahnemühle (PhotoRag, Bamboo and PR Bright White).
In black only mode on Bright White I get something not too warm, but
this paper contains OBA.
By the way, I had a look on the market: the
only "neutral" available pure carbon ink is Jon Cone's Piezography, I'm
afraid...
Sylvain.
On Tue, 10 Jul 2012 14:39:47 +0200,
>> Thx
Ernst. However, you give the Lab values for the paper itself only. What
I'm looking for is a paper giving neutral tones with EBONI inks, in the
high lights as well as in the shadows. Regards Sylvain.
> Paul Roark's
Eboni-1400 PDF gives a good impression of what Eboni diluted and Eboni
Black Only does with various papers. The Eboni is not neutral itself to
start with and it will be hard to get a full range neutral without color
toning that ink. -- Met vriendelijke groet, Ernst Dinkla Grafische
Techniek Quad, piëzografie, giclée www.pigment-print.com [1]
Links:
[1] http://www.pigment-print.com
> I'm currently using Hahnem\ufffdhle (PhotoRag, Bamboo and PR Bright White).
> afraid...
> Regards
> Sylvain.
Wonder how pure that carbon is then :-)
In a practical sense and for people living outside the US it may be
easier to use the HP Vivera source and rely on the good tests results
instead of going for the pure carbon goal. The same PDF quotes HP Vivera
PK as being neutral and I can add HP Vivera MK in that category too. The
Vivera Grey inks can be used as well but more than the PK they tend to
give bronzing on most gloss papers. PK diluted with transparent ink
media gives better results and will be cheaper. I use an OCP gloss
enhancer for that and an HP K5400 with thermal heads to print with, ink
and ink medium suit the thermal heads. Paul uses one type of MIS ink
medium to do the same for pi\ufffdzo heads. 130 ML or larger carts of HP
Vivera inks are not that expensive and easily available.
The Photorag Bright White gets warm quite fast in time.
Re: Looking for a neutral matte paper with Eboni
2012-07-10 by Paul
> is also welcome :o)
For black only Eboni printing and OBA free papers, see
http://www.paulroark.com/BW-Info/R1800-No-OBA-Paper.pdf
This was part of the 1800 3-MK write-up.  The tones are the same as those with a 1400 BO, however.
For brightened papers, see
http://www.paulroark.com/BW-Info/R1800-OBA-Papers.pdf
If the graphs are not self-explanatory, see
http://www.paulroark.com/BW-Info/R1800-Paper.pdf
For dilute Eboni-6, see http://www.paulroark.com/BW-Info/Eboni-6.pdf
In general, Eboni black only or the 3-MK approach appears to be the closest thing we have to a neutral 100% carbon image.  Diluting the Eboni causes the tones to be warmer on most papers.  Also, the 1.5 pl printers are a bit warmer than the 3 pl printers with dilute Eboni.
For a coated inkjet paper, the Epson Hot Press papers -- both natural and brightened -- should be tried.
If toners are used to cool the carbon, I'd recommend OEM inks.  Epson LM and LC may appear to have done the best in http://www.aardenburg-imaging.com/ testing on at least a few papers I've checked.  But, all we have are the 100% C and M patches to rely on.
Check out the graph on page 6 of http://www.paulroark.com/BW-Info/4000-6K-Plus.pdf .  Some paper takes to little color to neutralize the carbon, that I doubt the fading of top color pigments would be of much consequence.  In short, once you find a paper that you like and is relatively neutral, it may be that getting it to exactly the tone you like takes so little color that it's not particularly relevant to  longevity.  Remember that 100% carbon is a benchmark.  The more color added and the quality of the color added are what cause the problems.
2012-07-10 by Pete Bergstrom
> afraid...
I don't believe this is pure carbon (based on information from the
website).
I happen to use the Piezography neutral inkset and like it a great deal. In
terms of color it reminds me of Oriental Seagull paper after a light
selenium toning (using Canson Infinity Rag Photo paper).
I once put in a sheet of an unfamiliar, high-grade paper with the wrong
face for printing, and got an interesting puddle of slightly bluish water
with clumped pigment regions, so I've seen firsthand that there is
something in the inkset for cooling the image down.
Best regards,
Pete
Re: [Digital BW] Re: Looking for a neutral matte paper with Eboni
2012-07-11 by Sylvain M.
Thx a lot Paul.
I think I'd better stay with HPR. BO mode gives
me quite neutral tones in high lights and slightly warm shadows (Lab B
just under 4), which is not that bad finally.
Last question: I usually
consider a tone as neutral when Lab B is between 0 and 2. Am I right?
Sylvain.
On Tue, 10 Jul 2012 16:17:01 -0000, Paul wrote:
HPR, for example), OBA-free, that would give the most neutral tone as
possible (or even a little bit cool) with Eboni inksets. Of course the
best Dmax is also welcome :o) Could anynone give me an advice?
> For
http://www.paulroark.com/BW-Info/R1800-No-OBA-Paper.pdf [1] This was
1400 BO, however. For brightened papers, see
http://www.paulroark.com/BW-Info/R1800-OBA-Papers.pdf [2] If the graphs
http://www.paulroark.com/BW-Info/R1800-Paper.pdf [3] For dilute Eboni-6,
see http://www.paulroark.com/BW-Info/Eboni-6.pdf [4] In general, Eboni
than the 3 pl printers with dilute Eboni. For a coated inkjet paper, the
tried. If toners are used to cool the carbon, I'd recommend OEM inks.
http://www.aardenburg-imaging.com/ [5] testing on at least a few papers
http://www.paulroark.com/BW-Info/4000-6K-Plus.pdf [6] . Some paper takes
what cause the problems. Paul www.PaulRoark.com [7]
Links:
[1]
[2]
[3]
[4]
[5]
[6]
[7]
http://www.PaulRoark.com
2012-07-11 by Paul
>... I usually consider a tone as neutral when Lab B is
As a practical matter, I think think that is correct.  Of course, dead neutral would be Lab A and B = 0.  However, a one unit difference is barely perceptible.
Actually, I think viewing conditions are huge factor.  I have Arches watercolor paper prints on the wall that look very neutral.  In fact, however, the paper base is creamy warm (about Lab B = 3), as is the natural paper mat board.  The image tone (Eboni-6) peaks out at about 2.5 units above that.  Yet, because the eye appears to do a "white balance" on the Arches paper and mat board, the prints look neutral.  The image tone, being about 2.5 Lab B units warmer, if we look at the differential between the nearby paper white and maximum image warmth, is close to your estimate of 2 as what people will see as "neutral."  Most viewers, seeing the prints without another reference, simple consider then B&W prints -- no obvious tone at all.
The mistake many people seem to make is to view their prints and test strips next to their 6500k monitors or next to very bright typing paper.  In comparison the prints with even slight warmth look "brown."  If those are the conditions that one expects the prints to be viewed in, by all means, use paper with lots of OBAs and inks that are almost half color pigments.  For that type of print, I even prefer the Claria/Noritsu dyes on bright, high gloss paper.
The point is, lighting and display conditions make a big difference.  When I was hanging shows that were a mix of neutral silver-gelatin and inkjet prints, I tried to use inks that would match the silver print tones.  While I still keep a silver print hanging in my office for reference, as long as the prints are not side-by-side, no one sees any difference between the silver and Arches/carbon prints.  (Actually, I do.  The carbon on Arches are usually better.)
2012-07-11 by C D Tobie
Its b*, not B, but yes, both a* and b* should be near zero to indicate neutrality. b* alone only indicates yellow to blue neutrality; a number with a neutral b* value could still be screaming green or bright red.
C. David Tobie
Global Product Technology Manager
Datacolor
5 Princess Road
Lawrenceville, NJ 08648, USA
609.924.2189
www.datacolor.com
Phone: 207.685.9248
Mobile: 207.312.0448
Fax: 207.685.4455
Email:  cdtobie@...
Skype: cdtobie
2012-07-11 by Paul
> Its b*, not B, ...
http://en.wikipedia.org/wiki/Lab_color_space  seems to explain in technical terms the difference between the two Lab notation types:
"A Lab color space is a color-opponent space with dimension L for lightness and a and b for the color-opponent dimensions, based on nonlinearly compressed CIE XYZ color space coordinates."
"The coordinates of the Hunter 1948 L, a, b color space are L, a, and b. However, Lab is now more often used as an informal abbreviation for the CIE 1976 (L*, a*, b*) color space (or CIELAB). The difference between Hunter and CIE color coordinates is that the CIE coordinates are based on a cube root transformation of the color data, while the Hunter coordinates are based on a square root transformation."
Is there a practical difference in the usual B&W gamut?
I notice that my Spyder3Print, when measure a test strip, simply lists "L=__, a= __, and b= __" (with no * used).  Are these the Hunter 1948 L, a, b, or the CIE 1976 (L*, a*, b*)?  Or does it really make no difference?
ICCLab, actually, which is based on CieLab, but with the values limited to 0-100 for L, and positive/neg 127/128 for a and b.
C. David Tobie
Datacolor
5 Princess Road
609.924.2189
www.datacolor.com
Phone: 207.685.9248
Fax: 207.685.4455
Email:  cdtobie@...
Skype: cdtobie
