Re: [Digital BW] Epson 1400 Printing Issues
2013-04-26 by Paul Roark
The glossy paper may show printer artifacts more than the matte paper. Some printers show some microbanding when the image is formed mostly with the cool LC-C inks. (That was what was behind my thought of adding a second LC in the place of the Y. It will take different profiles, however.) Paul www.PaulRoark.com On Fri, Apr 26, 2013 at 1:08 PM, remononaz1 <homershannon@...> wrote: > ** > > > I made two 11x14 prints last night and found that the second one had very > fine horizontal lines in it. (direction of printer head movement) These > show up most distinctly in the middle gray areas and are fine enough to be > invisible at more than 18" away. > > The first print, which is perfect, was printed on Red River Art White > paper (matte finish) with the UT-14 ink set and an ICC developed for that > paper. > > The second print was printed on Red River Ultrapro Satin (satin finish) > with the UT-14 ink set and a color curve to produce a neutral tone and > prevent surface problems with the carbon ink. The printer setting was gamma > 2.2. > > I checked the ink cartridges and all are at least ¾ full. I ran several > nozzle checks which are all perfect. I ran the alignment tool. Still the > lines persist. > > I have seen this issue before with Ultrapro Satin paper and the curve. Is > it possible that the curve has something to do with it? Other than more > cleaning, which does not seem to help, what is recommended? > > > [Non-text portions of this message have been removed]
