Epson 1400 and thick papers
2013-07-27 by livingwithbugs@...
I am setting up a refurbished Epson 1400 and running into the (well know?) issues with thick papers. As I understand it the paper thickness is set in the driver not buy a lever as in older printers. The problem is I am running under linux so I don't use Win or Mac drivers. Has anyone else encountered this dilemma?
Re: [Digital BW] Epson 1400 and thick papers
2013-07-27 by Paul Roark
300 gsm papers go through a 1400 with just a little manual assist in
feeding; no driver or other changes are needed.
If they don't it's usually because the feed roller is dirty.  Some papers
foul it.  Running a sheet through that is sprayed with Windex seems to work
to clean the roller(s).
Re: Epson 1400 and thick papers
The paper I'm trying to use is 315 gsm (Innova STNW). Since the printer is new (refurbished) I think the rollers are probably clean. The problem is that the rollers grab the paper ok but then an error is generated (flashing red light) and the paper is ejected. My guess is there's a "paper thickness sensor" that is being triggered by the slightly too thick paper. If I could set the "envelope" switch the print head would move a little further away from the paper. Unfortunately the envelope setting is done in the driver instead of manually (I think).
Thanks
Jack DeAngelis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Paul Roark <roark.paul@...> wrote:
> Paul
> www.PaulRoark.com
Re: [Digital BW] Re: Epson 1400 and thick papers
2013-07-27 by bengui
> manually (I think).
> Thanks
> Jack DeAngelis
> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>, Paul Roark
> to work
> > Paul
> > www.PaulRoark.com
> (well know?)
> is set in
*Try running an Epson adhesive page through your printer. Paper dust on
rollers can cause the problem you describe. I usually run my own
adhesive pages (several vertical mounted strips of double sided 1/2 -
3/4" scotch tape on a page of typing paper) through my 1400/1430 several
times when I'm using thick paper that is being rejected. It usually
solves my problem.
Tom Hefter*
2013-07-28 by J.F. Felinik
Very strange, I just printed Innova Warm Cotton Gloss here today on my
1400, (it's 335 gsm), and no problems what so ever.. Maybe the printer need
some kind of adjustment/service ?
http://felinik.com
http://www.facebook.com/jf.felinik <https://www.facebook.com/jf.felinik>
2013/7/28 <livingwithbugs@...>
> Thanks
> Jack DeAngelis
> work
> > Paul
> > www.PaulRoark.com
> know?)
> set in
2013-07-28 by Keith
I have two 1400's both bought at the same time. One will load and print perfectly Bockingford Inkjet paper, weight 190g.
The other will not load whatever I try, I have cleaned the feed roller, tried a gentle push, also put a piece of low tack film at the point that the feed roller hits the paper, also tried the envelope setting, all to no avail.
Only one point that I can think of is that the machine that feeds OK has always had Epson Claria carts in it, the other machine has a home made pigment setup, based loosely on Paul Roark's.
Keith Dugdale.
2013-07-28 by Vincent Wan
On a 1430 I've had problems feeding Canson 310gsm RAG Photographique but not Epson Hotpress Natural 310gms.
I found that I needed several sheets in the feeder for it to feed reliably (I wound up using bad prints, printed side down, so that I didn't waste new paper.
Vincent Wan
August 2012 PhD. Committee on the Conceptual and Historical Studies of Science, University of Chicago.
Once and future professor of Biology
2013-07-29 by David Kachel
I noticed.
  I noticed a problem with the 1400 and one matte paper yesterday that I
have experienced before, so I thought I would share the solution.
This first happened to me with an HP B9180 and Red River's Aurora paper. It
drove me nuts for a long time.
With some papers, inks don't dry fast enough and the rollers drag wet ink
down the paper leaving streaks parallel to the long axis. These can be very
subtle and tend to occur more often when heavy ink deposits precede lighter
areas.
It has never happened to me with an Epson printer and any paper till now,
but it happened yesterday with the 1400 and the warm carbon ink set with
which I am experimenting.
With a more advanced printer, the printing speed can be slowed and the
problem presumably solved that way, but the 1400 doesn't allow that option.
The solution is tedious, but entirely effective: stand in front of the
printer with a hair dryer (new, or you'll fill your printer with hair
particles) and blow dry your print through the feeding slot as it is
printing. (You can understand why, among other reasons, I ditched HP
printers!)
David Kachel
___________________
Artist-Photographer
Fine B&W Photographs
www.davidkachel.com
david@...
Gallery:
www.reddoorfinephotographs.com
director@...
PO Box  1893
Alpine, TX 79831
(432) 386-5787
2013-07-29 by J.F. Felinik
I've never seen pizza trails on the 1400 with matte papers, maybe your exit
rollers need a bit of cleaning? Try running the thickest watercolor paper
you can find, through the printer a cpl of times.
My 1400 is ok as long as I keep the rollers clean, and I print mostly
surface papers with the UT-14 set. Though dark and dense prints is a no no,
on those occasions I always get trails. Ended up getting a 7600 instead as
it feed the paper in a different way (no exit rollers). During the next
week I'll pimp it up to a Piezography printer.
http://felinik.com
2013/7/29 David Kachel <david@...>
> I noticed.
> areas.
> printers!)
> David Kachel
> ___________________
> Artist-Photographer
> www.davidkachel.com
> david@...
> Gallery:
> director@...
> PO Box 1893
> Alpine, TX 79831
> (432) 386-5787
>exit
The marks I was talking about are NOT pizza wheel marks. That's something
entirely different.
David Kachel
___________________
Artist-Photographer
www.davidkachel.com
david@...
Gallery:
director@...
PO Box  1893
Alpine, TX 79831
(432) 386-5787
Oh, I see now, sorry for the confusion.
http://felinik.com
> >exit
> entirely different.
> David Kachel
> ___________________
> Artist-Photographer
> www.davidkachel.com
> david@...
> Gallery:
> director@reddoorfinephotographs.com
> PO Box 1893
> Alpine, TX 79831
> (432) 386-5787
2013-07-29 by Jack DeAngelis
*Sounds like these feed issues are hit or miss to some extent. Thanks to
all that responded and I'll certainly post a follow up if I learn anything
new. At this point the culprits are (1) dirty feed roller; (2) Linux/Wine
issues - no access to the "envelope" setting from Linux; and (3)
differences in paper thickness/surface texture. Can someone confirm that
there's an "envelope" setting in the Mac Epson driver? I'm considering
setting up a dedicated Mac printer station to eliminate Linux/Wine from the
equation. Thanks.
*Jack
I'm on Mac OS X 10.7, and I have that setting on the Epson driver for my
1400, in the control panel under "printers" when chosing the printer and
clicking to see more options.
http://felinik.com
2013/7/29 Jack DeAngelis <livingwithbugs@...>
> equation. Thanks.
> *Jack
Re: Epson 1400 and thick papers - SOLVED!
2013-08-02 by livingwithbugs@...
And the winner is ... dirty/oily feed roller! The confusing part was that the paper sometimes fed ok but thicker paper generated a "paper out"/"double feed" error. This made me think that the problem was a paper thickness sensor and hence a problem in the Linux driver. Turns out that the thicker paper just caused a slight skip at the start of the feed because the roller was slipping. The printer translated the skip into a "double feed" error. My guess is that the roller was contaminated with oil (this was a new/refurbished printer) because once cleaned with ALCOHOL (see below) the errors stopped.
I found an Epson 1400 service manual that recommended an industrial strength method for cleaning the feed roller. They suggest attaching a piece of cloth to an index card (I used staples), dampen the card with alcohol (I used 80% ethanol but 70% rubbing alcohol would probably work), hold the cloth/card in front of the feed roller and press the paper button (hold on tight!). I did this several times. The windex-dampened paper method might have worked as well but I think alcohol has a better chance of dissolving oil/grease.
Thanks again for everyone's help, I'm back in business.
Jack DeAngelis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jack DeAngelis <livingwithbugs@...> wrote:
> equation. Thanks.
> *Jack
