Best way to mount prints
2013-10-23 by <ben@...>
I recently found this 'scientifical' document about the long-term effects of mounting digital ink jet prints to Aluminum and Dibond supports.
I wonder if the traditional setup print+passepartout behind glass is better or not.
I talked with several people about it, but everyone seems to have his/her opinion.
Can I find somewhere good research results about this?
Thank you,
Ben A.
Belgium
Re: [Digital BW] Best way to mount prints
2013-10-23 by jimbo
Interesting article thanks for sharing it.. Your right everyone will have their own opinion.. What I can tell you is that within museum conservators you will find varied opinions.. I went thru this with Gator board and similar materials some years ago.. I will try a few searches to see what I can come up with relative to aluminum. What I learned with gator board was that a proper barrier was necessary between the image and the board.. So in the tests that Queens University did it is certainly a valid test but tests typically raise more questions or what if's?? The first that comes to mind is the bonding tissue used.. Is it a valid archival barrier and bonding agent. Regarding the fact that the Premium Luster failed quicker or had more negative effects then a cotton material doesn't surprise me at all.
This is a pretty good group and you have a pretty good topic here.. hopefully a few can offer some insights..
jimbo
  Sent: Wednesday, October 23, 2013 9:52 AM
  Subject: [Digital BW] Best way to mount prints
  This is the doc I talked about in the beginning: http://www.queensu.ca/art/artconservation/research/projectsMAC/TessaThomas.pdf
  Thank you,
  Ben A.
  Belgium
  No virus found in this message.
  Checked by AVG - www.avg.com
  Version: 2014.0.4158 / Virus Database: 3614/6773 - Release Date: 10/22/13
2013-10-23 by Paul Roark
At least based on a quick read, the results look consistent with what I would expect. Matte paper, un-mounted, appeared to do the best. RC paper, mounted, gets micro-cracks.
I don't know the limits of the test procedure they used. It's different than what I have heard of before for age testing. Still, it did not appear to cycle the temperature and humidity.
Consistent with the test, if I wanted to make the best glossy mounted printn, I would consider using aluminum. On the other hand, given the use and markets that I have in mind for glossy, I'm not sure it matters.
I would still bet on un-mounted Arches (un-coated watercolor paper) looking the best a few centuries from now. But, I don't expect to live that long. So, to enjoy my images the most, I have mounted, un-glazed B&W dye prints on my office walls, plus one 100% Eboni carbon on Arches print hanging under acrylic on a different wall, in part, to remind me that what I believe to be the ultimate in longevity can look great even when my top, relatively short-lived dye eye-candy prints are also on display.
It's good to see some testing going on and being disseminated. Thanks for posting.
jimbo
Thank you,
Ben A.
Belgium
2013-10-24 by Ernst Dinkla
On 10/23/2013 05:52 PM, ben@... wrote:
> Hi,
> better or not.
> his/her opinion.
> Thank you,
> Ben A.
> Belgium
Ben,
It is a very short summary, nothing more than the usual research
"poster". I tried to find the real article but couldn't.  My main
concern is the vacuum oven. That is a very rough method which heats the
media but also dries it to unnatural levels. I have seen it used for
roofing materials etc. I suspect that the RC polyethylene layers loose
their flexibility fast and components of the Gudy mounting material
create "solvent" bubbles in between the RC and the aluminium surfaces of
both mounting board types. Both will not happen with a pure paper base
print. If humidity would be varied instead the pure paper print may have
more issues than the RC when mounted on aluminium. Not to mention the
protection against abrasion.  I am not in one camp and so far have only
used Photorag prints mounted on aluminium and DiBond.
Yesterday I did send a PR print to the lamination shop for mounting on
aluminium, repeat job, a profile on the back of an aluminium mounted PR
print was not glued properly and the print fell on the floor after 6
years. No complaints about the print quality, a Z3100 product, or the
mounting method.
Met vriendelijke groet, Ernst Dinkla
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
December 2012: 500+ inkjet media paper white spectral plots.
Re: Best way to mount prints
2013-10-24 by Richard Eskin
This test was seriously confounded by several uncontrolled factors:
1. The way I read it, the unmounted samples were not placed in the oven, so all that was compared was aluminum vs dibond, with no actual control; you cannot determine how aluminum and dibond differed from standard mounting.
2. The bonding agent also was not applied to the "unmounted" samples which presumably were the controls, thus you cannot separate differences due to the bonding from effects due to the backing.
3. All of the observations were qualitative so if there was any variation between the samples the significance of the differences cannot be tested statistically.
4. Because the dibond has a relatively non-conducting layer, the "effective" heat of the dibond may have been higher, while the aluminum could radiate some of the heat (which is consistent with the results, but may not be applicable at normal temperatures).
5. This experiment tested only the physical damage to the papers, not impacts to the inks such as relative color changes.
6. "Aging" is determined by multiple factors such as UV exposure, air borne contaminants and acidity, which were not tested, so this is a very narrow definition of ageing and limits the applicability of the study.
Richard Eskin
Richard.Eskin@...
410-825-2503
443-415-0349 (cell)
RichEskinPhoto
We can see the human spirit of a particular age expressed in the landscape, and we can comprehend it with the camera. -- August Sander during a 1931 lecture on the ability of photography to help make sense of one’s environment and circumstances.
A room hung with pictures is a room hung with thoughts. -- Joshua Reynolds
“A clear vision, backed by definite plans, gives you a tremendous feeling of confidence and personal power.” — Brian Tracy
RE: Best way to mount prints
2013-10-24 by <214mark477@...>
The reason that you will get different answers about mounting is because different people and organizations have different needs in terms of display and conservation. No mounting technique is perfect for all people under all conditions. For example, just hinge mounting a print so that it is not permanently mounted to anything is preferable for many museums for many types of prints. However, this leaves the print more susceptible to developing some curl especially if the print will be displayed in a location with significant changes in humidity. A fine art collector might appreciate the wave in the print but your average consumer will think it is a poor mounting job not a museum archival mounting job.
If you are going to mount it to a substrate you need to consider three things:
1. will the process (temp, pressure, adhesive) damage the print
2. will it be permanent
3. will the substrate you are mounting it to damage it over time
For example some dry mounting is common for photographs however, if you use too high a temp in the press it may damage an inkjet print. Archival t-hinging sometimes uses water activate adhesive but this is wrong to use on the original dye based inkjet prints. You can use a spray adhesive and manually apply it however it is difficult to get the adhesive fully activated and to completely remove the air from underneath the print so the print may bubble and start to peel after a few years. A roller press with pressure sensitive adhesive instead of heat activate adhesive can be better for an inkjet print that is temperature sensitive. If temperature is less of an issue then a dry mount press may be used with heat activate adhesive. In the case of a roller or a dry mount press, use of a film or tissue adhesive gives you a better chance of 100% application of the adhesive, 100% distribution of the adhesive, and 100% removal of air therefore creating much more permanent mount.
The nice thing about not mounting the image is that over time as the frame or display package items get contaminated by things like paint in the wall and airborne contaminants you can eventually exchange everything with fresh components. This is what a museum that wants things to last forever will do.
Once you have the image mounted there is the issue of protecting it. Glass and acrylic are both ideal in that they provide great protection and are completely inert so they do not harm the print over time (as long as they are not allowed to touch the print). They may also have a UV-filter that provides additional protection.
The drawback to glazing such as glass or acrylic is that they will tint the light, reduce the light, and possibly introduce reflections that all can reduce the vibrancy of the image a little. Cheap glass will cause a lot of green tint. Museum glass will have nearly no green tint and very little reflections but will still have a very slight warming effect due to the UV filter. Nothing is perfect.
If you leave the glazing off you are exposing the print to more UV radiation, other light radiation, airborne contaminants and greasy fingerprints, but until that stuff ruins the print, the print will look fabulous.
If you use a spray coating or laminate you get some protection back but you also introduce chemicals on the print. Over time the coating may interact with the print or the coating or laminate itself may yellow over time. In either case you are stuck with end result.
In the end you have to ask how long do you need it to last and can it be replaced. Some people just need a few days, other a few years, others a few lifetimes.
Mark
President
www.framedestination.com
Thank you,
Ben A.
Belgium
