I just got my first digital camera, and thought I should revisit printing -- a lot happens in ten years, right? So much, that I'm not sure how to make up for lost time. I visited B+H last week. The salesman said that the Canon Pro series were much less prone to clogging than the Epsons.
Sanders,
I am assuming your primary pursuit is B&W, since you asked on this list.
When you print B&W with an OEM color ink set you end up having to repeatedly buy inks you don't actually need very much. Their (Canon, Epson, HP) algorithms mix in color inks to get the desired gray tone effect in what they consider an optimal way, but in large part the color inks are just expensive place holders, unless you are toning your B&W images. Even then, you will still have a couple of inks that aren't used.
With Canon printers, you have to keep two extra ink slots filled with color inks you don\u2019;t need. A pointless additional expense. (I've only looked at a couple of Canon printers. They may not all be this way.)
Also, if you buy a Canon printer, then the use of B&W aftermarket ink sets is permanently closed off to you. Only Epson printers are open to this approach in a practical way due to the availability of cartridges, inks and QTR, especially. And even with Epson printers, you have to buy one for which aftermarket refillable cartridges exist. They are not available for all models.
If you will be printing some color and can buy only one printer, the choice is clearly Epson. Their Advanced Black and White system will allow you to get quality B&W images more long-lasting than Canon's and still be able to print color. I personally don't care for ABW, but I am after print tones most other photographers don't want. Most people using ABW are very pleased with it. (I know you didn't ask about HP printers, but just in case, BITE YOUR TONGUE!!!)
Probably the best printer to get is the Epson 3880. It is about $1100, depending on sales, rebates, etc., and will take a beating. I have a 3800 I started seriously abusing with my ignorance about five years ago. It has aftermarket B&W inks in it and just recently gave me a totally clear nozzle check which it hadn't done for years! Apparently, they have some sort of on board healing!! ;-)
My setup now is a 3880 with OEM color inks, and the 3800 with six B&W inks and two color toners. Or, you can follow Paul's game plan and have a 1400 or 1440 with aftermarket color inks in it for those rare color jobs that don't need maximum permanence.
The Canons are pricier and far less versatile. No brainer.
David Kachel
___________________
Artist-Photographer
Fine B&W Photographs
www.davidkachel.com
david@...
Gallery:
www.reddoorfinephotographs.com
director@reddoorfinephotographs.com
PO Box 1893
Alpine, TX 79831
(432) 386-5787
