Re: [Digital BW] Epson 4900 not printing VLM or LC / Gary / Arthur
2014-02-07 by mrjimbo2
First to answer your question you can typically see it .. Open the hood and look. I have a small flash light that I use on some printers where visibility is difficult.. but it will show up.. A power clean typically will get them out but you could also pull them out with a syringe but that in my experience has gotten a bit messy with me at the helm...:-)..
Ok I forgot something very important in my last post.. some how I was thinking it was the 7900 not the 4900...Ok the 4900 does not have a pressurized ink system.. (have the 4800 ) Anyway they use an ink reservoir of sorts .. so repeated efforts at cleaning or nozzle tests can run the reservoir dry especially if it's starved. So going slow with these guys is in my experience the way to go.. If you seem to be going backwards then just stop.. wait several hours and come back.. or the next day.. Also if the channels that are giving you a hard time are low on ink..(pull the carts and shake them to make sure your good to go) put fresh carts in those channels then after the issue is resolved put the old ones back in to finish them.
Ok, one more thing.. this is for printers that set for some time.. I posted this once before and freaked everybody out.. or think I did.. The inks can settle in your lines. So they can get a bit sludgy on the bottom.. When inks start moving thru the lines again I think it's possible that improperly mixed inks are moving inside the tubes.. ( No I can't prove this ..it's a theory) Anyway, I have a printer set up with K6 and if it sits for a while the images are always screwy.. Soooo I now occasionally tape a battery powered egg shaped vibrator that is adjustable ( yes it exactly what you think it is) to the lines and let it run for 5 minutes or so... the vibrations get to the entire line length and it put all the particles back in suspension.. To be honest I don't really notice that much difference on color images but I sure do on B&W ..
jimbo
Sent: Friday, February 07, 2014 9:43 AM
Subject: RE: [Digital BW] Epson 4900 not printing VLM or LC
Jimbo,
How can you tell if you have air in the line?
Gary Wagner
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of mrjimbo2
Sent: Friday, February 07, 2014 8:37 AM
Subject: Re: [Digital BW] Epson 4900 not printing VLM or LC
Arthur,
It winter , really low humidity and it sat for a while.. So a couple of things you can do / try.. First make sure the two colors that won't show don't have air in the lines..
Next wet the park pad with water.. really wet it .. ( I use an eye dropper for this) Put the head over it for an hour or so.. Then try a nozzle test to see if your getting anything if you start seeing a few lines go ahead and do a regular cleaning cycle.
If that doesn't work , This one you'll want to keep an eye on so you don't start wicking ink out thru the head.. wet a paper towel with a mix of water and simple green... fold it in half to double its thickness... get that in the rollers manually...make sure it's good and wet even if you have to add more with an eye dropper.... then pull the head off park and let it set on it for several hours.. (no windex or similar as that dries it out).
As far as Epson saying you need a new print head.. well too soon to say that I think..... you might have a damper issue or simply struggling with air in the line...
jimbo
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2014.0.4259 / Virus Database: 3697/7071 - Release Date: 02/07/14
RE: [Digital BW] Epson 4900 not printing VLM or LC / Gary / Arthur
2014-02-07 by Gary
Jimbo,
Thanks for the info! My yellow nozzle test is completely blank. Have you
used PiezoFlush and do you think it would do any good? I am not sure if this
is a head clogging or if something else is broken or clogged and no ink is
reaching the head. When I do the paper towel soaking all of the other inks
are drawing onto the towel. One day it was working producing a good check
and the next day it stopped completely.
Gary Wagner
Sent: Friday, February 07, 2014 9:40 AM
Subject: Re: [Digital BW] Epson 4900 not printing VLM or LC / Gary / Arthur
jimbo
Jimbo,
Gary Wagner
Arthur,
the line...
jimbo
Hi Gary,
Given the series of the printer (4xxx) and my experience with this series in low humidity and temp environments I'm not suprised. Again I honestly feel the most important attribute you can have is patience with these guys when they get stuck.. If you have not tried simple green on a paper towel I would do that first.. Water has an effect on the inks but simple green literally dissolves them.. If you have enough of it on the paper towekl a bit of it should get into the head thru the nozzle openings..
Yes, Piezo flush is a great product and I would do that for sure before I called the Epson guy.. Just do it to the one channel.. At least that way you won't have to deal with getting the fluid out of the other channels and it'll be easy to see in the Yellow channel.
Another thought .. I'm in a really Epson hazord area here.. winter humidity is less then 20% often 15% .. I know many people put a humidifier in the room etc etc.. I do that also but in some situations is not that effective or practical.. Soooo I have several clear plastic silver ware trays that I purchased from Bed Bath & Beyond.. their approx 2 1/2 to 3" wide, 2" deep & maybe 10+ or so inches long. I also picked up several 1 1/2 inch thick sponges from the hardware and cut them to fit the trays.. I soak them with water and actually leave a puddle of water in the bottom of the tray so they last longer.. These go in all my printers.. from one to several of them depending on how they fit.... open the hatch put a few in and close the hatch.. They last several days and in my case are actually more effective then a humidifier.. but of course it's a PIA to say the least.
Do you have a service manual for the machine.. Might want to look at the dampers also.. something might have headed south their also.
This time of year is the hardest on a printer as far as functionality goes.. Whatever their used to from a humidity stand point typically they will get less at this time of year..
jimbo
Sent: Friday, February 07, 2014 10:52 AM
Subject: RE: [Digital BW] Epson 4900 not printing VLM or LC / Gary / Arthur
Jimbo,
Thanks for the info! My yellow nozzle test is completely blank. Have you used PiezoFlush and do you think it would do any good? I am not sure if this is a head clogging or if something else is broken or clogged and no ink is reaching the head. When I do the paper towel soaking all of the other inks are drawing onto the towel. One day it was working producing a good check and the next day it stopped completely.
Gary Wagner
jimbo
;----- Original Message -----
Jimbo,
Gary Wagner
Arthur,
jimbo
2014-02-07 by Gary
Jimbo,
Thanks for the help. I think I will try the PiezoFlush next and see if that
helps. I will also try the water to keep the other inks working. I have had
problems with the cyan but it usually comes back with a few cleanings. The
yellow just stopped and has not restarted now for two weeks. Still hoping to
come up with a solution. I do not have a maintenance contract and replacing
the head cost is not worthwhile compared to buying another one new. Counter
shows 850 prints over two years. Makes the cost of the print go up if I
can't get it working.
Gary Wagner
www.garywagner.com
Sent: Friday, February 07, 2014 10:58 AM
Hi Gary,
jimbo
Jimbo,
Gary Wagner
jimbo
Jimbo,
Gary Wagner
Arthur,
the line...
jimbo
Well good luck.... sometimes they just get stubborn..
jimbo
Sent: Friday, February 07, 2014 12:12 PM
Jimbo,
Thanks for the help. I think I will try the PiezoFlush next and see if that helps. I will also try the water to keep the other inks working. I have had problems with the cyan but it usually comes back with a few cleanings. The yellow just stopped and has not restarted now for two weeks. Still hoping to come up with a solution. I do not have a maintenance contract and replacing the head cost is not worthwhile compared to buying another one new. Counter shows 850 prints over two years. Makes the cost of the print go up if I can’t get it working.
Gary Wagner
www.garywagner.com
Hi Gary,
jimbo
Jimbo,
Gary Wagner
jimbo
Jimbo,
Gary Wagner
Arthur,
jimbo
2014-02-08 by <nicholae@...>
A few group members have suggested using Jone Cone's cleaning solutions but were unable to say if they are any good. Our computer labs run a fleet of 13 Epson Printers all with a varying degree of obstinance. Weather changes wreak havoc on the print heads (almost more so than our students).
The only cleaning solution we've had overall success with is Piezoflush from inkjet mall, run by Jon Cone.
For cleaning out the printhead this time, I suggest purchasing a set of empty cleaning cartridges with a large amount of cleaning solution. Load the carts, fill them up, and do an initial fill in the printer (they usually send directions on how to do this). Send a few prints through the printer to get the solution to run through, or even just a few power cleanings. Once nozzle checks come out clear, replace the cleaning solution with ink carts and refill the printer.
Next time you need to leave your printer sitting for more than a few weeks, you'll have the cleaning cartridges and cleaning solution - just load those into the printer and let it sit with THAT in the lines rather than ink. This will save your ink lines and printhead from damage and in the long run will save you more money.
Hope this helps
Nick Enghardt
St. Edward's University Advanced Imaging Lab Manager
Austin, TX
2014-02-09 by Gary
Nick,
Thanks for the info. I ordered some Piezoflush on Friday. Hopefully it will do the trick on my nonworking yellow.
Gary Wagner
www.garywagner.com
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of nicholae@stedwards.edu
Sent: Saturday, February 08, 2014 7:18 AM
Hope this helps
Nick Enghardt
Austin, TX
2014-02-11 by <nicholae@...>
Gary,
Not a problem. I sometimes have to get a little creative with clearing clogged heads and printer maintenance in general. If you have any other questions on how to get your printer back into shape without spending $2K on a new printhead, feel free to contact me directly - nicholae AT stedwards DOT edu.
Good luck!
Nick Enghardt
